Question about LG DLE5977 Electric Dryer
My LG DLE 5977 S Dryer doesn't dry the clothes completely. I have to restart it multiple times to get a load to completely dry.
    President:
  • 3,773 Answers
Check to see if there is a kink in your vent hose in backj.
Go outside to verify
Clean filter with dishwashing liquid and brush
Run water on filter first to verify it doesn't go through
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Posted on Sep 11, 2010
Our dryer doesn't dry clothes like it should, sometimes takes a long long time and other times quick and the clothes feel really hot, model # is DLE 2532W
see this causes and fix it. God bless you
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Sep 27, 2012 | LG DLE2532W Electric Dryer
LG Dryer Model # DLE 2050 W is not drying. It is getting hot but clothes remain wet even after 2- 1 hour cycles. The information panel is blinking with a message that says "FLOW SENSE". The...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Feb 14, 2011 | LG Dryers
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
LG Tromm DLE Dryer never dries my clothes when the cycle is done
ok there,first the clothes must come out off your washer well spun,or dryer will work extra hard/long.next you dry a load with out ducting to elimanate your house venting[you wont hurt a thing]most off the time thats it![house]if still bad and you know your dryer is cleaned out then its an electrical problem.will go ther after you check the above.God bless.please help with my ratings if i have be helpful,tom
Jan 02, 2009 | LG WM2688HWM TROMM SteamWasher
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
LG DLE5977 Electric Dryer Logo
204 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
