Question about Vizio L32 32 in. LCD HDTV
Tv turns itself off as soon as I turn it on: it will not stay on
  • lucywerner00 Sep 12, 2010
    I called Vizio and they had me do the hard reset. It did not work. I also tried the compressed air to clean the TV on the outside of the unit, ie I did not open it and spray the air on the TV components.
  • 18 Answers
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you, if it does, let me know by coming back and voting. Thanks!
Posted on Sep 12, 2010
  • gundog61 Jan 02, 2011
    I had the same problem. Hard boot did not work. I final asked them about a firmware update which they send out on a usb doggle. They said that they would send it out and that it would repair the TV. So it apears ther many be a software bug that needs to be fixed with updated firmware.
After a power surge TV controls will not work have to hold the volume button to turn up the volume
Stephanie, TV will have to come apart to check for bad capacitors,etc. on the internal board.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Toshiba Televison & Video
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
My lg plasma shuts off as soon as its turned on
Sustain board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 04, 2014 | Televison & Video
Magnavox about 7-10 years old as soon as i turn it on it turns off and stays off
my 42 inch sagem tv is overheating, the red light comes on, then 2 lights come on and then turns off, and light stays on. and only turns off when you disconnect tv. When i turn on the tv after 1 min the light flashes, the tv turns off and the light stays on.
Sep 18, 2011 | Proton MM2701VT 27" TV
Tv wont turn on (wont stay turned on)
pls. check power coad is likage or luse canaction in plugh
if ok then problum is inside of tv so pls. cheked in pcb.....
1st : SMPS output voltage and 5v /12v/ 24v /135v dc filter capaciter cheked and replace 470/16v /1000/35v / 220/450v if any capaciter likage or sort * first cheked dyode.
2nd : EHT output line capasiter or dyode checked 4.7/250v /100/160v
and line coil or 1ohm register cheked
3rd : DT (driver transfermor ) and with cancting spear dry.
note: pls descanect tv with DVR and cheked tv set is turn on atlist 10min. minimum with any ather product (DVD , GAME BOX ,CABEL CANACTION) if is ok. then problum in DVB setup box .
Oct 04, 2009 | Samsung LN40A550 LCD TV
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
LG 42PC3D Plasma TV Will Not Stay On
Could be a failing poser supply
Apr 22, 2017 | Televison & Video
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Volume turns down
Enasni,
It's probably a tact switch problem, something we call in the industry awindex syndrome. The tact switches, depending on the ones effected, can turn the tv on/off by itself, channel +/- at will or in your case control the volume.
Tact switches are not expensive to replace but a bit difficult to get to if you're not trained. They are at the very front of the board - looking from the back - and some disassembly may be necessary to take the main board out.
A reputable shop wouldn't charge much do fix this problem, switches are about a dollar a piece.
Good Luck
Bill
Nov 25, 2007 | JVC AV-27D305 27" TV
Vizio L32 32 in. LCD HDTV Logo
747 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
