I cann;t receive several network channels on my Dynex 26: L150A11 LCD TV using only an antenna (no converter box). Does this TV have a built-in digital tuner? Do I need to use anything else to connect ?
  • 201 Answers
all new tvs should have a built in digital tuner. Make sure that tv is set to receive antenna signal and not cable by going into the menu. Use autoprogram feature if you haven't done so already. it will lock onto whatever signal is strong enough for it to see. Also if you are using an indoor antenna it may not be able to get enough signal to the box. Indoor antennas are not the greatest especially if the station is far away.
Posted on Sep 11, 2010
How do I connect my dynex tv with a converter box to an outside antenna, it has me stumped...thank you
  • Connect the outside antenna to the ANTENNA input of the box
  • Connect the red, white, and yellow outputs of the box to the corresponding inputs on your Dynex TV
  • Apply power to the box and TV
  • Select a video input as the signal source to the TV. You should see a box menu displayed on the TV
  • Run a channel search to store active channels in memory
You should be good to go
Apr 19, 2018 | Dynex Televison & Video
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to antennaweb.org and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
Aug 24, 2016 | Olevia LT26HVX 26 in. LCD Television
How do I get channel with my Dynex televison?
Yes all over the air channels are now digital. Make sure that your TV is on the correct source. You can get a decent converter box at Walmart for around 20 to 50 dollars
If you need further help, I’m available over the phone at https://www.6ya.com/expert/aaron_a0d6f580814d28b2
Feb 02, 2015 | Dinex Dynex DX-LCD26-09 26 in. HDTV-Ready...
DO I NEED A CONVERTER BOX FOR MY 32' DYNEX TV, OR JUST A RCA ANTENNA
It depends on the input you have on your TV. Please go through operation manual for guidance.
Jul 31, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
Do i need just an antenna or one of those digital converter boxes to get just local channels in Denver on this TV?
If your TV was made after 2007 it should have the digital receiver built in. If so you can just hook any antenna you wish up and receive all your local channels.
Jan 15, 2010 | Sony KV-35S42 35" TV
Panasonic Viera LCD TV Can't Find Channel 7
I can't receive channels 3 and 6 right across the Delaware in Philly. Welcome to the club.
Aug 15, 2017 | Panasonic Viera TC-L32C12 32 in. LCD TV
Can I use a regular antenna
Yes. You can use a regular antenna for any flat panel HD TV. You're only limitation the type of antenna and whether or not your flat panel TV has a built in digital tuner. If it does, you'll be able to scan for digital channels without any additional components, including the High Def ones,  though you may not get every channel available with a set of rabbit ears. A roof top antenna will give you a stronger signal and more channels. If your TV does NOT have a built in digital tuner, you'll have to purchase a digital converter box and attach your antenna to it to receive the digital and HD channels. Good luck.
Jun 30, 2009 | Panasonic Televison & Video
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
I have a DYNEX DX-R20TR, is this tv digital ready?
Hi dlcase777,
Good news, your TV has both Digital and analog tuners. You will only need an antenna to recieve digital OTA (over the air) signals.
I have provided a link for information on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Thank you for the oppurtunity to help and please rate this solution as a FixYa.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 31, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
