Question about Monster Cable MCC AVL300-S Remote Control
Remote says Safe Mode - Monster Cable MCC AVL300-S Remote Control
How do i remove the remote from safe mode?
Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
1. Ensure the Remote is in "Safe Mode Requested" by taking out the batteries, and disconnecting the remote from the USB cable.
2. Hold down the Off button and plug the remote into the USB.
3. Continue holding down the Off button for another 10 seconds. The remote should then display the words "Safe Mode Requested".
4. With the unit in "Safe Mode Requested", re-install the firmware by clicking Support on your home page.
5. Click Firmware in the Downloads section and follow the online instructions to upgrade the firmware.
6. Once the firmware upgrade is complete, click Update My Remote.
7. Insert new batteries into the remote.
Jul 27, 2010 | Logitech Harmony 659 LCD Remote Control
Tip
Logitech Harmony Firmware Update
Logitech Harmony Safe Mode Fix
Is your Logitech Harmony Remote stuck in SAFE MODE?
If you upgrade / update the firmware of your Logitech Harmony Remote, your remote will no longer be in SAFE MODE.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
Your Logitech Harmony has now had its firmware updated, and is no longer stuck in SAFE MODE.
I hope that helps.
____________________________________________
Harmony Mac Software Download
Harmony Win Software Download
Harmony Remote Glow Light Fix
on Apr 27, 2010 | Televison & Video
What is safe mode
Safe mode is what the remote will boot into if there is a problem with some of the software on the remote. It is the same as safe mode on your computer, where the remote will boot up with as little programming as possible to avoid hardware faults. To get the remote out of safe mode, you have to reapply the firmware onto it.
- connect the remote to your computer and launch the software - click downloads at the top of the screen - click firmware - update the remote
Jul 07, 2010 | Logitech Harmony 550 Remote Control
My Logitech Remote 550 is Locked in the Safe Mode. How do I get it our of Safe Mode.
Doing a firmware upgrade is the BEST way to recover from Safe Mode. A remote may go into safe mode itself for a variety of reasons.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Hope this helps
Sep 24, 2009 | Logitech Harmony 550 Remote Control
Remote is in safe mode
You can try this solution to your Harmony 550 Safe mode problem:
Harmony 550 Safe Mode Fix Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
Hope that helps.
Aug 18, 2009 | Logitech Harmony 550 Remote Control
It says safe mode
Hey!
I got my Harmony Remote stuck in safe mode and found the following link that got it working properly!!!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
I hope this helps!!!
-Kennedy
Aug 05, 2009 | Logitech Harmony 550 Remote Control
My harmony 550 remote is in Safe Mode and will not respond to any button I push. How do I get my remote to work again?
Did you try this response from the Logitech users' forum? It can't hurt to try since all your settings are stored on the web, not on the remote.
http://logitech-en-amr.custhelp.com/...i=&p_topview=1
Basically, Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
Jun 15, 2009 | Logitech Harmony 550 Remote Control
Harmony 1000 in safe mode?
The harmony remotes have a built in safe mode, similar to a Windows XP computer. Usually you enter the safe mode on the harmony remotes by taking the battery out, then pressing the power off button and holding while putting the battery in. If you continue to press the power off button, the remote will display safe mode on the screen.
If you are not doing the above procedure and you are still getting the safe mode on the display of the remote, I would try to update the firmware on the remote. And if you have an RF Extender, update the firmware on it at the same time.
Hope this helps,
81
Dec 19, 2008 | Logitech Harmony 1000 LCD Touchscreen...
Safe mode
NOTE: Ensure the new batteries are all the same brand.
Nov 26, 2008 | Logitech Harmony 659 LCD Remote Control
Frozen
Try this:
1. Remove the battery for a solid 2 minutes, then reinsert and see if that fixes it. if not 2. try updating the firmware with the remote in safe modeSafe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
  7. Insert the battery into the remote.
Sep 09, 2007 | Logitech Harmony 880 LCD Remote Control
Monster Cable MCC AVL300-S Remote Control Logo
437 people viewed this question
Top Monster Cable Televison & Video Experts
Electro Med Services...
Are you a Monster Cable Televison and Video Expert? Answer questions, earn points and help others
