Question about Dell OptiPlex GX260 PC Desktop
ERROR MESSAGE ALERT PREVIOUS ATTEMPTS AT BOOTING THIS SYSTEM HAVE FAILED AT CHECKPOINT PWRD
shoib127300
  • 55 Answers
SOURCE: my dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
Posted on Mar 17, 2009
whitebirch
  • 433 Answers
SOURCE: [Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Posted on Apr 27, 2009
3764alan
  • 127 Answers
SOURCE: Alert! previous attempts at booting this system
I'm not sure right off hand what the WRIT means. But other articles online seem to think that you should hit F2 at boot and check the Boot Order. One guy set it to CD and booted a CD (a bootable one) fine. I would make sure it set to the first Hard Drive. He also said something about: went to the "event log" section and cleared the last event (actually the only one showing). I saved the settings, then booted up again and this time it booted up normally.
* Anyway new hardware external or internal would be 1st suspect in this kind of thing. One person had problems after adding a new printer that had a memory card in it. Apparently the Dell tried to boot from the memory card.
Posted on Jul 07, 2009
  • 1481 Answers
SOURCE: Can not boot the system
if u realy want to make ur PC facotry fit....
visit my site
www.sureshayyar.110mb.com
Format Disk page
all detailas and necessary tools are available for download
Posted on Feb 05, 2010
swufabuda
  • 219 Answers
SOURCE: my dell dimension 4300 displays
make sure you keyboard is plugged in well. If that doesn't help try a different keyboard.
Posted on Aug 06, 2010
Alert sound dimension
Please do a fresh install or try to use System Restore to go BACK before this problem happened.
Jun 08, 2013 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
How do I fix this error "Previous attempts at booting this system have failed at checkpoint USB0?
go into bios and disable usb ports it should tell you while its booting up what key to press to get there like f1 or f2
Dec 08, 2012 | Dell Precision Workstation 670 PC Desktop
I keep recieving the message...previous attempts at booting this system have failed at checkpoint(poke).for help resolving thisnproblem please contact dell tech support.
If you made a backup disc use that disc and run the repair files options when you boot up your computer. Sound like one of the files got corrupted on hard drive.
Apr 18, 2011 | Computers & Internet
Hi im getting this error message whenever i try to tunr on my system "ALERT!PREVIOUS ATTEMPT AT BOOTING THIS SYSTEM HAS FAILED AT CHECKPOINT VINI - FOR HELP IN RESOLVING THIS PREOBLEM" cant get in to...
reinstall the operating system.It seems either a virus or someone has deleted an operating system file. But if its windows you can try a repair using the operating system CD.
Aug 02, 2010 | Computers & Internet
visit my site
Format Disk page
Feb 05, 2010 | Dell Dimension 8400 PC Desktop
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
My dell dimensions 4600 will not boot
Mar 17, 2009 | Dell Dimension 4600 PC Desktop
Can't Do Anything... NEED HELP!!!
"Alert previous attempt at booting the system has failed at checkpoint emem {EMem}."
This is a No Post issue and if youre going to check the quadpack it will show yygg which indicates memory failure.
Quick Step : Reseat memory
If cust has more than 1 memory, test each memory on each slots until you find the memory that’s causing the error message and send a replacement for the faulty memory.
May 19, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
238 people viewed this question
Alun Cox
