Question about Refrigerators
Our avant 323yb works. intermittently. It stops chilling unless we turn the temperature back off and on again. But eventually it will shut itself off again.
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
What does the Therm-O_Disc that's on the motor of my Kenmore Elite washer do
The limit switch is a temperature activated overload switch. When the motor over heats, the switch opens to turn off the motor. A few minutes later, after the motor cools off some, the switch closes to restart the motor. If the motor over heats again, the switch opens again to shut off the motor again. This process can repeat itself over and over again until eventually the motor will burn itself out.
Jul 23, 2015 | Kenmore Washing Machines
Water leaking from hose on water filter housing
shut water off to ref and try cutting the end of the tube off, but only 1/8 to 1/4 of an inch.. insert back into housing firmly and turn water back on and see if leak stopped.... if still leaking order and replace the filter housing..... hope this helps....... ken
Oct 09, 2014 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Help. Can't change oven temperature on Whirlpool when oven is hot.
YOU HAVE ISSUES WITH CONTROLL PANEL , NEEDS REPLACED
Jan 02, 2012 | Cars & Trucks
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
Need free help when trouble codes come up 1124 and 1128 no power unless you step on it then it takes of but as soon as you let off it dogs deown again no power
the antivirus has been playing whilst i have been at work so my codes programme doesnt work anyway firing up notepad and that has just locked up ,not my night tonight thats for sure .
P0124....Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
P0128....Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
right got them from other computer and from what they say then you need to change the throttle sensor ,its on the end of the throttle pedal ,but the other one is easy to fix check that you have a thermostat fitted ,if you have then whats the local ambient temperature where you are as you may need to block off the radiator with a piece of cardboard to stop the wind chill factor
Jan 21, 2011 | Hyundai Tiburon Cars & Trucks
Intermittent radio CD, etc. every 20 - 30 seconds the sound drops out and then resets itself. It is like the power is shut off and then is restored.
you probably need an amplifier if the power on the radio is not shutting off when this happens. this vehicle also has a fiber optic system that runs the radio so you'll probably need to take it to the dealer for repair
Nov 17, 2009 | 2007 Audi A6 Avant Wagon
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Kirby G5 intermittent power
I would say that it is a short in the power cord.
Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions, parts (cords too!!) and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Jul 31, 2008 | Kirby G5 Bagged Upright Vacuum
Fan on laptop intermittent Avent 7110
That can be normal. Normally cpu fans start up only when cpu reach a determined temperature. After it cools down it stops until temperature reaches starting point again.
Generally, when the fan is not working properly, the computer turns itself off after a while because of overheating.
If you have this problem, laptop turning itself off because of overheating (check it is not hibernating etc.), then you usually solve it by replacing the laptop cooling fan.
Generally, 'fan on laptop intermittent' is not a symptom of malfunction.
Apr 25, 2008 | Computers & Internet
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
