Question about Insignia 600W Bridgeable Amplifier with 12" Subwoofer
What can happen to the 600 watt insignia internally that causes the power protect light to come on ? can it be repaired?
  • Anonymous Mar 28, 2014
    prices on Insignia Amplifiers
  • 30 Answers
You could of shorted something out inside the amp causig there to be no output, the easiest way todo that would be if the power wire grounded out after the fuse while i was hooked to the amp. also its possible the ohm load was toolow for the amp to handle. and mst amps are repairable its just how much are you willing to spend. hope this helps
Posted on Sep 13, 2010
I have a 600 watt diamond audio amp hooked up to 2 pioneer 10s the amp comes on but slowly shuts down speakers have sound at first but gets lower as amp light dimms. What's going on. Also I have a boss 20...
Short circuited component/s at amps' audio output stage circuit. Contact any service technician to get it repaired. Short circuit protection circuit is built inside this set, and it will detect the internal short circuit, when it occurs, and will shut the set's power OFF, to protect the speaker and other components. That is happening here.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 06, 2014 | Car Audio & Video
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
JVC 600 watt amp overheated
Yes it has a protection mode, let it cool for while then try it again, if it over heats quick make sure you're not running the amp below its stable impedance.
Aug 30, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
My red light on my amp is on and wont go out
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
Apr 03, 2009 | Insignia 600W Bridgeable Amplifier with...
Tv won't turn on
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Nov 17, 2008 | Insignia LCDTV26 26 in. Television
Subwoofers seized up wont play
putting too much power to the subwoofer......i just blew mine now.....it was a 1600 kenwood exelon 500 rms watt sub.....powered with insignia 600 watt 2 channel.......ran 600 watt rms though......cooked it ......so if you can underpower it....just bc it sez 1600w doesnt mean you have to match it just dont go over!
Oct 15, 2008 | Audio Players & Recorders
No response from amp
it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Open Questions:
Insignia 600W Bridgeable Amplifier with 12" Subwoofer Logo
141 people viewed this question
Top Insignia Car Audio & Video Experts
Mark Skinner
Carlos Quintanilla
Level 1 Expert
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
