Question about GE Refrigerators
The freezer is icing up on the bottom. will defrosting it help?
  • 4,793 Answers
Frost or ice buildup is mostly associated with air leaks from the door seals.defrost then check seals.
Posted on Sep 11, 2010
Ice acumlating in bottom of freezer drawers..ice build up...icing up products in freezer, and keeping the drawer from closing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Viking DFBB363 Bottom Freezer Refrigerator
The bottom freezer "ices" up-
heatman101
Dec 31, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Water in bottom of fridge and in crisper drawers
the defrost drain in the freezer is clogged with ice.
empty the food from the freezer, and put through a defrost. you might have to help the fridge defrost with a hair dryer. you may also have to remove the rear panel (inside the freezer) or pending on the model to bottom panel of the freezer.. (usually held in by 1/4" hex screws.)
melt all the ice, and be sure that the drain is clear, and it should work.
May 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Kenmore upright freezer
you have a defrost system problem. Could be the defrost timer or defrost heater or defrost thermostat. Bottom filled with ice could be from a plugged drain system. Where you termed "condenser coil" is in reality the "evaporator coil".
May 24, 2008 | Zanussi ZEBF250W Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
