Question about Maytag Neptune MAH5500B Front Load Washer
Fixing error code 03 on a maytag neptune mah5500bww. It has been causing some problem with not wanting to start but has run after playing around with the buttons. How the display lights all work but the pause/on button and door lock button are not lighting up. I got a error code of 03 but have no idea what it means? Are there parts I ca buy or do I need to call a teck.
  • 2,272 Answers
The 03 error is related to drain problem in the washing machine.Open the bottom panel of the machine and access the drain pump and remove the drain pump and check the drain line and the drain hose connected to drain pump.Clean all the blockages and debris collected in the drain hose and in the drain pump .Then reconnect it and recheck.If still the same problem then the drain pump can be faulty and needs replacement.If the pump looks worn out and very old get it replaced.A lot of water will come out when you will remove the drain pump out.So keep the rags clothes ready. ------------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 11, 2010
Sludge on mah5500bww spinner support
That sludge is causing the error. The spindle is not being lubricated thoroughly and when the motor tries to turn it, it drags in spots and gives the unbalanced error. Clean it off and regrease it and if there is a seal or gasket, replace it.
Feb 05, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah5500bww motor/control board failure recall
I had Maytag ship a new motor and motor control board for free and installed it myself in less than an hour. There is a ten year warranty on those parts. You just have to be very firm and insist you have warranty rights by law!
Feb 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
I was wanting to know the year of the maytag neptune washer? model # MAH5500BWW
Try and get the serial number then contact a Maytag agent. The serial number in most cases is a date code.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
145 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
