Question about Amana Dryers
I have an Amana LG4319w/l2 gas dryer converted to Lp gas. The ignitor comes on but will not ignite the gas. Theis happened before and the technician replaced the ignitor and said the ignitor must dray a certain amount of current to allow the gas valve to open. How do you test to determine this problem? If it is the thermal protection unit that is defective will the unit be open or closed circuit? Any other area that I should look at?
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Ho to convert a frigidaire natural gas dryer to a lp gas dryer?
Kits should be available at Sears.com, need to be a certified technician to change it. Involves changing igniter, burner scoop, and adjusting air shutters.
Feb 22, 2014 | Frigidaire GLGQ2152ES Gas Dryer
I am looking to convert my kenmore 970-c92062 ng dryer to lp.
The supplier of the LP gas can supply the needed parts for conversion.
Aug 09, 2017 | Amana Dryers
Gas dryer starts out ok. When it needs more temp to keep drying, the glow plug turns on and waits for the lp gas to show up and nothing happens. My quess, 1. solenoid valve malfunctions 2. no flame...
heatman101
Sep 03, 2010 | Amana NDG5800 Gas Dryer
I have an LP Amana Dryer that I want to convert to natural gas. Do I need to take the dryer apart from the inside?
oh yea need to change orfices and possibly regulator cap rotation... if no ng kits available might need to order orginal valve as all appliances usually come factory with ng...... yes u must acess the internal components so u might need to remove panels and drum to get bettter acess
Apr 10, 2010 | Amana NDG7800AW Gas Dryer
My dryer is not heating up I cleaned the vback vent only cold air coming our its a gas dryer
From the picture posted, it looks like the bottom panel is removable.
If you can remove that and watch what happens when you turn it on, that will help. A glow igniter should turn on which once bright and hot, will ignite the gas.
If it glows, but you get no gas, it is probably the two electromagnetic coils that sit on top of the gas valve. There are online stores that sell them with a good return policy if that doesn't fix the problem... do you have a volt meter?
Jan 08, 2010 | Amana ALG331RAW Gas Dryer
Igniter keeps going out on LP dryer
Look at the gas control box. Inside this box has a valve to open the gas so it can sustain the burner. This valve is control by the voltage of dryer sensor. This thermocouple is near the ignitor.. If this fails, there would be no voltage to open the valve. Here is how it looks like: 7f43321.jpg
I recently purchased a used ARG 7300 gas range in god condition and had it converted to LP gas by the gas company. I am concerned that the ignitors for the range top don't fire until the knob is turned all...
You know I never thought about it but my stove you can do that with also. You can go right by the "lite" position and have gas coming with out it actually lighting and I have seen other stoves that are like you said. So I would say that the serviceman did everything correctly. It is up to the user to be responsible and make sure that the stove lights in a timely way when they are using it.
Nov 17, 2009 | Amana RanARG7302 Gas Kitchen Range
I have an Amana gas(LP) dryer DLG330RAW that doesn't heat. When I turn on the dryer the ignitor glows red, and ignites a great flame for about 10 seconds, then I hear a click and the flame shuts down. A...
Replace the two small round black solenoids located on the gas valvle. I just did it last week. They come in a set and only cost me $26.50. Easiest fix I've done. I was all set to go out and buy a new dryer.
Sep 24, 2009 | Amana DLG330RAW Gas Dryer
Amana LG4409L Gas Dryer: Ignotor comes on when
The igniter or gas valve could be defective.
Nov 18, 2017 | Amana Dryers
Gas dryer lg8319w/l2 doesn't keep heating after started
Hi, You will need to change the coils on top of the gas valve. If the ignitor glows but the flame doesn't come on, this is your answer. It is a very common problem with the gas dryer. If I can assist you further, please let me know.
thanks
Vic
May 15, 2009 | Dryers
Dryers Logo
108 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
