Question about Samsung SL600 Digital Camera
MY CAMRA WONT TURN ON AND MY LENS WILL NOT CLOSE WHAT CAN I DO TO FIX IT
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 11, 2010
5 Suggested Answers
SOURCE: the camra will not turn off and the lense wont close
I encountered the same problem, just last night. If it is the same, the only way I could get it to turn off was by taking the batteries out and the lens still would not retract. After re-installing the batteries several times with the same result, it would not turn off, I did this: I re-installed the batteries and powered up the camera, I applied a little force/pressure to the lens and it went back in. After that the camera seems to be working fine. I hope this helps, Mike
Posted on Dec 27, 2006
  • 6 Answers
SOURCE: lens error restart camra, how do i fix it?
USE FRESH BATTERIES & SLITE ROTATE THE LENS .
( DO NOT PUT OVER PRESURE )
Posted on Apr 15, 2009
wipdhuls
  • 133 Answers
SOURCE: lens is stuck
This happens when the camera is in the ON state and the battery power drains out completely. Please recharge the batteries or insert charged batteries and the lens would get closed automatically.
Please let me know if that works.
Thanks and Regards,
Srinivas
Posted on Apr 17, 2009
  • 6771 Answers
SOURCE: My Kodak Camra Wont Turn
This is a systems control board failure that controls all vital parts of the camera, it is cheaper to replace than repair, but make sure the battery is good because it will cause the same symptom.
Posted on Feb 04, 2011
My Kodak Camra Wont Turn On, And The Lens Wont OPen
Feb 04, 2011 | Kodak EasyShare C180 Digital Camera
Lens is stuck
Thanks and Regards,
Srinivas
Apr 17, 2009 | Nikon COOLPIX L18 Digital Camera
My camra has E18 on the screen
E18 is an internal error, the lens drive mechanism.
Canon has to fix it. If it is not under warranty, it will cost you around $160.
Apr 10, 2009 | Canon PowerShot A75 Digital Camera
Lens error restart camra, how do i fix it?
Mar 07, 2009 | Canon PowerShot A470 Digital Camera
Sony ericsson k800i
Solution:1
*Remove the memory stick and push the air (from mouth)into the Inner camera.After that it will work Fine.
Reason: If Dust in your camera lens, the error will appear, so it is a matter of sensor.
Solution :2
* Observe the problem little closer, and fix it, b'coz you know your mobile very well than the 3rd Person.
Jan 30, 2009 | Sony Ericsson K800i Cellular Phone
Digital camara zoom
samsung digitmax d73 zoom lens will not retract, just pull lens outward gently it will click, then turn on camra ,you should be able to zoom now turn off camra lens should return & close
hope this helps
Oct 17, 2007 | Samsung Digimax S600 Digital Camera
The camra will not turn off and the lense wont close
Dec 08, 2006 | Vivitar ViviCam 5385 Digital Camera
Samsung SL600 Digital Camera Logo
245 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
