Question about ASUS K50IJ-C1 Notebook
We want to disable the mousepad on an Asis K50i. How do we do it?
  • 39 Answers
Access the device manager on the PC then on the list provided go to the mice & other pointing devices category then expand that by either clicking on the Plus sign next to it then look for the name of the mouse pad right click on it & select disable.you can access device manager by doing this: click on start>right click computer>left click on manage>it will open up computer management then on the left side of that you will see the device manager option. that is for vista & windows 7. for windows XP start>right click my computer icon>select hardware tab>click device manager.
Posted on Sep 11, 2010
My computer can not use touchpad
check in device manager that the driver is properly installed and that the mousepad is not disabled. It is possible that the mousepad needs a driver. You should be able to download this from the acer website
Nov 23, 2012 | Acer Aspire 4741 4741g 4741z 4741zg 4743...
Disable mousepad asus laptop
Please explain what it is you are trying to do.
I'm not sure if you are saying your mouse pad is disabled or that you want to disable it.
Apr 05, 2012 | ASUS A53SVXE1 Versatile Entertainment...
How do you disable the mousepad on a HP Probook 4320s. I use a regular mouse and the mousepad on the laptop is very sensitive and causes the cursor to "jump around" and it is very annoying. I...
There should be an off indicator in the upper left of the touchpad. If you double click in this area, it will turn the touchpad off. You can confirm that it is off because a light will come on. If this doesn't or hasn't worked, go into your device manager and disable it from there.
Hopefully you have the drivers installed for the touchpad. You can find them here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=4145546&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=4145545
Good luck.
Mar 11, 2011 | HEWLETT-PACKARD ProBook 4320s C Notebook
Good evening, I just bought a new Packerd Bell laptop and i discovered a small but really annoying problem. When I am playing a game, I type and using the mouse at the same time. The only thing is when...
Check the mousepad settings in control panel. There are settings and programs that disable the mousepad when typing. A slight brush across the mousepad can send the cursor to odd places in your document.
There is also a small app that disables the mousepad when you type as well. Check your processe in task manager to see if there is such a program running in the background.
Jan 10, 2011 | Packard Bell 160240 Mouse
How to disable touch pad in asus k40IN series? I do not see touch pad settings?
This happend to me on a Asus U81 (Best Buy version of the U80) which has the Elantech mousepad
9.10 includes an X configuration utility called xinput. It is a command line tool. To see the many things you can do with this simply type xinput at a shell prompt.
Start by typing in:
Quote: xinput list This will show you all the input devices attached to your computer. You will need to know your mousepad's id to continue. On My Asus laptop the internal pointer was found as a "ImPS/2 Logitech Wheel Mouse". The Id I get after booting my system with my external mouse attached is 10.
Next you need to know how to disable the mousepad. So you need to know what properties it supports. the command is "xinput list-props" followed by your mousepad's id number, which for me was:
Quote: xinput list-props 10 The "Device Enabled" was what I needed to be able to use to switch it off. On my laptop this line was "Device Enabled (97): 1". The parenthesized number is the properties id number, the 1 that follows it is the value (0 will turn it off).
So now I need to set it such that the mousepad is disabled. My mousepad id is 10, property id I want to set is 97 and I need to set the property value to be 0. The option for xinput is set-int-prop which needs deviceid, propertyid, format of the value (8, 16, or 32 bit), and the value itself. For me this is:
Quote: xinput set-int-prop 10 97 8 0 To turn it back on:
Quote: xinput set-int-prop 10 97 8 1 Since this does its work on the X in memory it is not persistent. If you log out and back in the mousepad will be active again. This is desired behavior for me as I occasionally need to be able to use the laptop without my external mouse.
When I get a little time, I will write a small shell script that can toggle it on or off based on a grep of the output of "xinput list" and bind it to a key combination so I can do this without having to drop out to a script. (EDIT NOTE: See post #15 in this thread if you want the scripts)
One last note, xinput interacts with X. It will not be able to function at a normal terminal screen not running under your X. It will work just fine in an xterminal (the one under accessories menu).
Hope this helps.
Feb 19, 2010 | ASUS K40IN Notebook
Disable mousepad
hi,
try the Fn+F7 combo, the F7 is usually assigned to the touchpad and is indicated by an icon that's relevant.
This works on most notebooks to turn on or off the touchpad.
. Press F2 or F10 (it varies) to enter your bios setup screens. In these pages is a setting for touch pad only, mouse only or touch pad and mouse or serial. You might check that.
Jul 05, 2009 | Dell Studio 1537 Notebook
The cursor doesn't respond to commands given using mousepad.
Sounds like a malfunctioning touchpad. You could try an external mouse and disabling the touchpad in device manager.
Dec 13, 2008 | Dell Latitude D600 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
ASUS K50IJ-C1 Notebook Logo
126 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
