Question about EnGenius EOC-3220 (EOC3220)
We have a probleme whit engenius 3220 in security set web key and what is the encryption key 1, key 2, key 3 , key 4. If we change web for none in security we have a default encryption type mismatch after select the modem
  • 481 Answers
If you really wish to use WEP encryption, you should enter your WEP key in the key1 field. However, WEP is weak and breakable in under four seconds. I would recommend using the WPA encryption instead, with a passphrase. The AES mode is strongest, but the TKIP mode is compatible with more and older machines.
The reason you are getting "default encryption type mismatch" is because the encryption type has to be set exactly the same on the AP side and on the bridge side in order for you to communicate. When it is not the same type, you get this error. If it is the same type and you just have the wrong password, the error will be different.
Posted on Oct 27, 2010
I have a Engenius 3220, can't access on 192.168.1.1, I was change the firmware and can't connect now... are another IP to access, I try whit DDRT tool but not can see the IP.-
Try the program Belarc Advisor. It worked for me. I had the same problem when I updated the firmware of my EnGenius ERB9250 Extender. Once Belarc has displayed everything it has discovered about your computer, scroll down to the area labeled Network Map. There you will find your EnGenius 3220's IP.
Aug 22, 2011 | EnGenius EOC-3220 (EOC3220)
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
Cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
May 02, 2009 | EnGenius EOC-3220 (EOC3220)
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
How to secure, for example: get a password for my EnGenius wireless router EC-3220
Hi there!
What you can do is configure the wireless router with wireless security. By then, you'll be able to get a wireless key/ passphrase from the router.
Hope this helps!
May 04, 2008 | Computers & Internet
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
There no connection betwen my PC and eoc-322o
I have NO EXPERIENCE with this equipment; but have researched this to some degree on the internet. If you are willing to experiment with me we may both learn something. First thing I learned is the difference between ad hoc and infrastructure networks. I have a feeling the default for most wireless routers and wireless adapters is an infrastructure approach. From reading the EEOC-3220 documentation its default is called bridge mode which is an ad hoc network. (this would seem to require reconfiguring your wireless adapter whenever you move from indoors to outdoors -- not desirable.) This can be changed to an infrastructure network by configuring it as an access point which also appears to allow configuration of additional security options including WEP or WPA encryption and MAC checking and could allow hiding the SSID if desired -- all of which apparently could and should match your indoor wireless router. The preferable configuration for the EOC-3220 would be to set an IP address statically (dynamic may be possible) to one valid for the indoor wireless routers subnet and not already used in your indoor wireless router's subnet and disable DHCP on the EOC-3220 and allow your indoor network to control DHCP for the outdoor segment. From what I can tell this configuration should allow the two wireless devices to attach to your PC in a seamless or transparent manner.
Dec 01, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
170 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
