Question about Cycling
Can you raise the handlebars on a mongoose blackcomb
4 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: How can I raise handlebars on a 26 in. Mountain
You need an Allen wrench (a.k.a. hex key) to fit the bolt head right in the middle of the handle bars. Loosen this bolt just 2 or 3 turns then tap the head with a soft hammer or block of wood and a hammer. Then pull the handle bar stem up (and all of the way out so you can see how the wedge-shaped nut at the bottom of the stem works). Look for a mark on the stem telling you how high you can safely raise the bars (you have to leave enough of the stem inside the tube so that it will be strong.) Put it back in and tighten it up. If you found this helpful, please vote. Good luck
Posted on Jun 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: Just bought a Mongoose Spear
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between aerodynamics and uprightness when needed.
Posted on Apr 29, 2011
dunnbiker
  • 8546 Answers
SOURCE: What is the diameter on the mongoose blackcomb
It would be stamped right on the clamp area. Loosen the stem's front face and look. That would only tell you the size of the 'bulge'. Otherwise, measure the dimension you need with a caliper.
Click on the pic of the bars.
http://www.bikeman.com/content/view/1637/115/
Posted on May 27, 2011
How to raise handlebar
Open the Allen screw in the center of the handlebar stem by about 2-3 turns, then wiggle left and right until you have the proper height, retighten screw
Mar 12, 2015 | Mongoose 2008 Teocali Comp Mountain Bike
Raise the handle bars on my new mongoose bike
in the middle of handlebars you will see a hexadon bolt,when you got your new bike the right angle wrench should have been with it if so place the wreanch onto the bolt and turn anticlockwise this will loosen the nut,then pull the handlebars up until the wright is achived make sure they are straight then turn the wrench clockwise until it tightens,.Adrian....
Jan 23, 2015 | Mongoose Cycling
How do I raise the handlebars
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Jul 06, 2011 | Mongoose Domain Dual Suspension Mountain...
What is the diameter on the mongoose blackcomb handlebars?
May 27, 2011 | Mongoose Sector 26 Men's Full Suspension...
Just bought a Mongoose Spear (26"). How do I raise the handlebars?
Apr 29, 2011 | Mongoose Spear 26 Inch Men's Bike
We would like to raise the handlebars on a Mongoose Rock River Mountain bike but there doesn't seem to be a way to do it. We have no manual as it was purchased used. Thanks
Maximum height was determined when the bike was built and they sawed off the steerer tube.
There is no way to raise the stem vertically, short of getting a new stem that has a higher rise.
http://en.wikipedia.org/wiki/Headset_(bicycle_part)
Feb 20, 2011 | Mongoose Cycling
How do i raise the handlebar on a 1999 MGX bicycle?
You can only raise a quill stem os far safely. Loosen the vertical center bolt that's in line with the steerer tube a few turns and then tap down on it with a block of wood or rubber mallet to unseat it. The stem should be loose enough to turn independently of the front wheel. You can also raise it somewhat, but look carefully for the "maximum height" or equivalent markings etched into the stem body. Don't expose any more stem than up to that line. Line up your handlebars with the front wheel and securely tighten that bolt. It should be tight enough to vigorously resist independent rotation when you hold the front wheel bewteen your knees and attempt to turn the handlebars.
If it's a new-style threadless type stem, the maximum height was determined when they assembled the bike because they had to cut the steerer tube to be below the top edge of the stem. Go to a Bike Shop and have them replace the stem with one that has a higher rise or shorter reach.
Aug 22, 2010 | Mongoose MGX Maxim Dual Suspension...
Can the handlebar height be adjusted on the mongoose deceptor bike?
The stem could be flipped over if the rise change would result in a hgiehr handlebar, but it would be minimal. That style of stem requires the steerer tube to be cut at the time of assembly and spacers are usually installed that would allow lowering the bars but not raising them since steerer tube length can't be increased.
Or, get a stem with a steeper rise.
Aug 22, 2010 | Cycling
what kind of bike do u have? i have 5 years bicycle shop mechanic expierence, so i can tell ya if u give some more info
Nov 22, 2009 | Mongoose Cycling
Cycling Logo
101 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
