Question about Sanyo Televison & Video
The sanyo will play just fine for several days then there is sound but the viewing screen goes white. i have replaced all vidio cables. Checked the sat. signal by hooking up a second Tv. After sitting for a couple days then turning the tv on and off several times the picture will return but goes off again after a couple days.
  • hmlowery1 Sep 11, 2010
    What picture tube? this is a flat screen tv
  • 10,515 Answers
This is a common problem on Sanyo models.White screen is actually a good sign that indicates that the high voltage and other main power supply is working fine. This intermittent problem is due to either the video processing circuits or tuner section is bad.I would have predicted a faulty tuner, however as you said, you got a white screen with a video signal through the video input also - that rules out the tuner as the problem area.)
So, it looks like the video processing area is where the failure it. That will require a tech to troubleshoot it in search of the exact component failure (there are many, maybe over 100 components in that area). Once found it is probably a small, inexpensive part).However, this is a hardware failure and needs to be corrected.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
  • 712 Answers
I doubt it is the problem of the picture tube. A replacement may make it work fine.
Posted on Sep 11, 2010
My tv comes on shows a picture for a few seconds then it goes to a white screen no sound comes on. the screen says your tv does not support this programs content protection. replacing the tv HDMI cable...
Well either your HDMI source or the HDMI processing part of the TV is not right.
Try a different HDMI source and if the problem persists then it's the TV and you probably can't fix it on your own.
Or, of course, if you can use component cable just stay with it and save time and money.
Aug 11, 2014 | Sanyo Televison & Video
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A300 Digital Camera
Sanyo xacti digital camcorder screen not working when opened out
Hi!
It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
Sorry for the bad news, but hope this helps.
Tom
Sep 27, 2009 | Sanyo Xacti E1 Waterproof Camcorder
Radio works but cd plays with no sound
you probably have your amp hooked up to your power antenna remote. there should be another blue wire (probably blue with a white stripe) that is for amp remote.
Sep 09, 2009 | Eclipse 5442 CD Player
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Sanyo DP26648 cable problems
I have a sanyo dp26648, just had it over 90 days and it quit. I can hear the sound, but no picture at all. Just a bright white screen. I can't even go to the menu. I bought the extended warranty but there in not anyone in my area to fix it. They told me I would have to wait until they found one close.
momdukes
Sep 10, 2008 | Sanyo HT32546A 32 in. Television
Sanyo katana
sounds like you dropped it quite a few times
Apr 25, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Televison & Video Logo
41 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
