Question about Schaerer Siena Espresso Machine
Owners manual for Schaerer Ambiente Expresso Machine
4 Suggested Answers
  • 4 Answers
SOURCE: schaerer ambiente
if you are in usa, contact schaerer direct on:
Schaerer USA Corporation
2900 Orange Avenue, Suite 102
Signal Hill, CA 90755
Phone
888.989.3004 (within the U.S. and Canada)
562.989.3004 (outside the U.S. and Canada)
Fax
562.989.3075
E-mail
info@schaererusa.com
Service Dispatch
Select option 1
Technical Support
Select option 2
Parts
Select option 3
Accounting
Select option 4
Sales & Marketing
Select option 5
or Canada:
Quality Coffee Systems is at
1122 Boundary Road, Burnaby, B.C. V5K 4TK
E-Mail: qcs@telus.net | Phone (604)291-6166
Posted on Apr 11, 2008
  • 92 Answers
SOURCE: TRYING TO FIND A PART
I can e-mail it to you. You need to check or contact "Fix Ya" and ask if is OK. for me to e-mail it.
May be you don't have to ask, I don't know the rules.
Posted on Jan 11, 2011
yeaandrew
  • 38 Answers
SOURCE: schaerer ambiente display saying" selection locked
the machine seriel number and or cust, number are missing you need a " service card or the machine " save data card "
Posted on Dec 09, 2011
How do i operate the old espressomatic coffee machine
I assume you mean the expresso machine by Supramatic? Give me a correct manufacturer.
Try this link:
Espresso Machines by Supramatic Super Automatic from Schaerer Saeco Jura...
Feb 17, 2015 | Coffee Makers & Espresso Machines
Set grinding and extraction on ambiente
Grinder setting will not just affect extraction time, it will also affect taste. A fine grind will be slower but have a creamier look, a coarse grind will speed up delivery. From whatever setting you are on look at the result, you are after the good creamy top of a good expresso. only adjust one step at a time, and check a few cups before any more adjustment. You do not want it so slow that you have to wait ages, So go for coarsest grind with a creamy head. Overtime you might have to readjust due to wear, Select only one hopper at a time to adjust, Do not try and adjust when blending, one side at a time until both give same result and speed for same coffee, Then you can go onto blending.
Mar 05, 2013 | Schaerer Ambiente PS Espresso Machine w/...
My shaerer machine (ambiente) is giving error, selection locked, heating steam. Need help. Thanks.
This is quite common on steam boiler when the level probe is not reached within a specific period of time. Reason is due to limescale buildup which restricts water flow...
You need to remove and descale the fill pipe to the steam boiler. If its very badly blocked, you can drill out the blockage with a 7/8mm drill bit and then leave it soak in descaling solution until its clear and you can blow through it. Also you will find a small restrictor between fittings somewhere back from the fill pipe (between the fill pipe and the fill valve). This is a small disc shape with a 0.8mm bore in the centre, you'll need to check that this is clear also, they are notorious for blocking up due to small size. You can clear this using some very fine wire or if you have the Schaerer expander baffle pen. Be careful not to lose this restrictor when loosening the brass fittings as it is extremely difficult to find if you drop it into the machine. Good luck
Dec 29, 2012 | Schaerer Siena Espresso Machine
Schaerer ambiente locked in the flash mode
If you have a Ambiente p/s espresso machine;
it may be stuck in cleaning
simply turn the machine off.. press and hold down the on / off & cleaning button release them at the same time look for the word " Clear Flag " if you see that word you should be out of the cleaning mode ... Note coffee boiler may not be up to temp.. or water flow is blocked..
Feb 21, 2011 | Schaerer Siena Espresso Machine
TRYING TO FIND A PART MANUL FOR A SCHAERER AMBIENTE ESPRESSO MACHINE MODEL-15SO S/N 0521428262 210 VAC 5200W 25AMP 50/60HZ
Jan 11, 2011 | Schaerer Siena Espresso Machine
Schaerer ambiente display saying" selection locked
Nov 29, 2010 | Schaerer Siena Espresso Machine
Just had our schaerer ambiente-1 espresso machine worked on by a certified shop (visions in seattle) yesterday and today it is still putting out water with the steam. please help! --of course visions is...
First You need to check the inlet water valve, I think the plunger is not working (sealing) properly and 2nd. Check the water level probe make sure is clean. If you don't feel comfortable doing this take it to a pro.
Nov 20, 2010 | Schaerer Siena Espresso Machine
My shaerer expresso machine (ambiente) is giving error, level steam probe, when this happens it will not steam. This problem does not happen all the time and can be cleared by shuting machine off then...
"level steam probe" occurs when it takes more than two minutes to fill the water in the steam boiler. The easiest solution is low water pressure to the machine. Does it have a water filter? replacing it will probably help. Other problems could be the fill valve is not opening fully and or scaled water lines going to the steam boiler. The first thing I would do is activate the hot water tap and look at the pressure. If the water is coming out slow then I know its a restriction to the machine.
Nov 10, 2010 | Schaerer Siena Espresso Machine
Flowmeter error on an Ambiente Espresso Machine for Dunkin Donuts
Flowmeter A restriction of water flow.. is the drink interupted when you see this message if so replace flowmeter.. if not look for the blockage of flow coffee in the inlet tube to brew group,, calcified hot water boiler inlet tube plugged pistons..
Sep 27, 2010 | Schaerer Siena Espresso Machine
Schaerer ambiente
Phone
Fax
562.989.3075
E-mail
Service Dispatch
Select option 1
Technical Support
Select option 2
Parts
Select option 3
Accounting
Select option 4
Sales & Marketing
Select option 5
or Canada:
Apr 05, 2008 | Coffee Makers & Espresso Machines
Schaerer Siena Espresso Machine Logo
1,291 people viewed this question
Top Schaerer Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
