Question about Qca Spas Jewel Series Topaz Plus Hot Tub
Qets way too hot - i have turned the dial all the way to cool and "stand by" not sure what that is but its not getting any cooler? We bought it used and have limited info on it, the reference card says minimum temp is 65 and max 104. It feels like 104 and wont get cooler.
  • 310 Answers
This would indicate that the heater relay is stuck in the closed posistion giving constant power to the heating element.
Either that or thermostat dial is broken
Posted on Oct 28, 2010
How to Use Different Stand to Cooling the Laptop?
get a cooling pad / fan that runs off the usb port.
http://www.officeworks.com.au/shop/officeworks/p/deepcool-n6000-notebook-cooler-annbn6000
You know why they are called notebooks rather than laptops ?
Because they get really hot when placed on a lap !
Oct 18, 2016 | Computers & Internet
I have a compaq cq61 laptop , before few days my laptop fan stopped working nd my laptop back side getting verry hot after using 30 minutes ..bt laptop nt getting shuts off bt laptop is getting verry slow...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
also you could buy a laptop usb cooling pad 3-LED FAN USB NOTEBOOK LAPTOP COOLING COOLER PAD STAND or something similiar the cooling pads are very cheap and very good thing for your laptop
hope this helps
May 23, 2011 | Compaq Presario Fan
Laptop turns off when it gets hott
hope this helps
Apr 23, 2011 | Acer Computers & Internet
Processor is very hot by 100% in stand by!
Laptop? Blow out the bottom fan area with air. Listen and make sure the fan is working. you cannot put these on beds where there is no air circulation unless you put a flat object underneath it. USB coolers can be bought at Walmart. If the fan is shot...so is the motherboard until you can get it replaced.
Jan 04, 2011 | Computers & Internet
My water cooler won't cool water. The hot is piping hot and the cold is very warm. what should i do?
Check to see if fans are working i just bought a used one and one of the fans was not working and i fixed it and sems to be working
Nov 07, 2010 | Hamilton Beach Water Cooler with Storage...
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Ive just bought wr450 is it normal for bike to get hot if just left running on the stand bike is 2006 model. when you turn off you can hear the fluid in resovoir not the rad. ive been told this is not...
If there is no radiator fan to cool it off , it will sure get heated up if the bike is on a stand.
Its the wind tht blows through the radiator once the bike is in motion tht cools the fluid.
Nov 14, 2009 | 2005 Yamaha WR 450 F
Sunpentown SF-609 Evaporative Air Cooler - no cool air
Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Qca Spas Jewel Series Topaz Plus Hot Tub Logo
91 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
