Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
I have a gaggia syncrony compact. Everything works well, except the coffee doesn't come out the proper outlet. Intead, the grinds and all the liquid goes into the waste compartment.
  • 1,089 Answers
Your thumbscrew is stripped. If you remove the brew unit and push down on the thumbscrew your filter screen should have a gap in it. You need a new thumbscrew. Don't use the key to tighten it. That is why they call it a thumbscrew. Finger tight.
Posted on Sep 11, 2010
Its telling me that coffee beans are empty...but they are not..it makes grinding noise but the message keeps popping up beans are empty
You have one of 2 problems either the grinds chute to the brew unit is blocked, or the grind is too fine.
Sep 18, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Digital Syncrony. The machine
Hi
You could have a micro switch in the doser that is going bad and needs to be replaced. They are a special micro switch that is very sensitive and can get stuck with a little coffee dust inside the switch.
Mar 10, 2010 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Jan 04, 2010 | Gaggia Syncrony Compact Coffee...
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
71 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
