Question about Black & Decker Leaf Hog Blower Bv4000
How do I change over from blower to vacum - Black & Decker Leaf Hog Blower Bv4000
    President:
  • Black & Decker Master
  • 1,545 Answers
Open the bottom vent where the air comes in...there should be a locking clip there that when depressed with a screw driver will allow it to open...Install the vacuum tube in the opening made by opening the vented bottom...then remove the plastic blower tube and install a collection bag on the outlet where the tube was.
Please vote on this solution.
Posted on Sep 11, 2010
My heat and ac do not work. Can you help?
you broke the vacum line that goes from the drivers side of the throtlebody to the vacum actuator inside the dash underneath the passenger airbag
Nov 08, 2011 | 2000 Chevrolet Astro
2002 dodge stratus heat a/c /blower works but only blows out vents i cant change to anything else
the cable which switches the airflow direction is disconnected... either at the flap or behind the dash. If it is vacum controlled, then check for vacum leak.
Ck
Feb 13, 2011 | 2002 Dodge Stratus
Control settings will not change so the blower fan does not push any heat or defrost.
It sounds like the blend door is not switching. Many times a broken vacum hose under neath the hood will cause this. The blend door is vacum operated, if one of the hoses is cracked you wont have a functioning blend door. Usually with the vehicle running and hood open you may hear a hising noise. Locate it and fix it.
Dec 01, 2010 | 2002 Chevrolet Blazer
My car was searched going through customs and they searche dall the wiring above the passenger side knees (below glove box). Now my Ac/Defog/heater won't turn on. Is there a connection in point for the AC...
If you mean the blower doesn't work they may have unplugged the blower motor which is located behind the glove box with the plug pointing down I believe. The cover under the glovebox is also where the signal flasher is.
Nov 30, 2010 | 1992 Buick Regal
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do you convert the vacum to a blower?
Im guessing ... remove the device you are vaccuming with and put it on the other end of the air stream. Is yours both a vacuum and a blower???
Oct 18, 2009 | Garden
Vacuum works, but blower doesn't
Make sure that the vacum houseing on blower is closed all the way and/or snaps shuts to engage for blowing once you have removed all vacum attachments.
Mar 16, 2009 | Toro Super Blower Vac
Switch or blower motor
check your vacum hoses. you may have a vacum leak .
Feb 20, 2009 | 1990 Ford Probe
97 jeep wrangler blower
you have managed to disconnect a vacum hose either under the dash when you instaled the blower or you have disconnected the vacum hose under the hood close to the firewall look for ths hose it is a very tiny vacum hose!!!!
Oct 25, 2008 | 2005 Jeep Wrangler
Vent blower
Hello.Yes,it is a vacume problem.What happens is that the vacume controled a/c control head looses engine vacume because the one-way vacume valve fails.This valve is located near the firewall.Follow the vacume tube coming out of the evaporator housing in the engine compartment.
Sep 28, 2008 | 1999 Ford F150 Regular Cab
Black & Decker Leaf Hog Blower Bv4000 Logo
251 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
