Question about Onkyo TX-DS484 Receiver
Can't reset the dolby digital on the receiver
  • ccprivado Sep 12, 2010
    You took tolong to reply and I had a manual. I ended up having to buy another receiver. Please refund my credit card.
    President:
  • 2,777 Answers
I can definitely help you with this but need a bit more info.. what do you mean you can't reset the dolby digital? When you try to watch something that is encoded with Dolby what does it do? Des it work normally otherwise with regular un-encoded signals?
Thanks, Tim
Posted on Sep 12, 2010
    President:
  • 2,047 Answers
The process to reset the dolby digital can be found on pages 20, 21 and 22 of the user manual. Here is a link to download it incase you dont have it.
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds484_manual_e.pdf
hope this solution has been helpful?
Posted on Sep 11, 2010
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Denon Avr-3200 Dolby Digital not working
What I suggest is that you reset the receiver as you mentioned. If you look in your owner's, there will be a procedure that says, "Return to factory default, or Reset" I believe you have it set wrong, or are not providing it with Dolby Digial signal. Dolby Digital, is not processed by the DSP board(Digital Sound Processor), which handles the THX, Neo, and every other format. Dolby Digital, is one of the earliest form of Home Theater. It has to be processed through the 2 RCA jacks(left and right). It is really not used anymore, in light of Dolby Pro Logic, THX and others.
Dec 14, 2012 | Denon AVR-3200 Receiver
Cant get sound from right and left rear speakers
Your source will determine the Dolby Digital capabilities. WHAT is on video 1 and is it Dolby Digital?
Jul 04, 2010 | Kenwood VR-407 Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
HK AVR35 Receiver - Dolby Digital not displaying or working
If the display is showing as optical/PCM, then the input signal is in 2 Ch Stereo.
Try to change the signal from the source i.e. the DVD player, On the remote, go to audio and press repatedly , the audio would change from audio1, audio 2 .... and so on, depending upon how may have been recorded on the DVD. If the DVD is recorded in Dolby Digital, it may show the audio as Dolby Digital 5.1 on you monitor. Once this setting has been done, your Receiver should automatically detect it and show as Optical/Dolby digital.
Please let me know if you you solve your problem.
Mar 12, 2009 | Harman Kardon AVR 35 Receiver
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
No dolby digitaL ON BLU-RAY FIMLS played thro a ps3,
prologic is a form of dolby digital, the 4.0 or 5.1 (versions I and II respectively) to be exact. the type of dolby version is determined by the source disk. the reciever may expand a dolby digital signal into 7.1 but it is actually a 5.1 standard, as is prologicII
Nov 28, 2008 | Denon AVR-3801 Receiver
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
May 19, 2008 | Marantz SR-7200 Receiver
Yamaha htr-5240 dolby digital problem
Is there switch from dolby pro logic/ surround / or analog/ digital?
Sep 27, 2007 | Yamaha HTR-5240 Receiver
Onkyo TX-DS484 Receiver Logo
95 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
