Question about Simplex Kaba Ilco Unican 1000 keyless lock
How do you remove a unican from an existing door? I was able to remove inside knob but there are no visible screws to remove the plate.
  • 963 Answers
I
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Mar 06, 2011
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
Hi, I have an older version of the Ilco unican corp pistol safe. IT is a simplex with the push buttons and a silver turner. I got it open, but don't know how to re program the code. Any help?
pctuneup191
REMOVE THE KEY.
Good Luck!
Feb 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible...
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Oct 02, 2010 | Top Knobs M826 Door Pull
How do I remove a door knob when there are no visible screws
There are several types of methods used, look for anything like a small wire, or the like and push it, and release. Also the round plate releases and you can see screws and retainers, on the inside side of the lock,
Oct 01, 2010 | Schlage ND96PDEU-OME ND96EUOME612 Satin...
Door lock is loose
Inside plate arond the base of the knob needs to pop off.
Try removing the knob from the inside. Look for a place the push in with a flat head screwdriver. A release point is there some where.
After the knob is off the plate should come off and reveal the screws.
Mar 30, 2009 | Kwikset Professional Door Lock...
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
371 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
