Question about Simer Plumbing
I have a Simer 2800 jet pump. I use it to water my garden from a shallow well. Its water output has decreased significantly. I have reasons to believe that the nozzle is clogged (when we had flooding here in Rhode Island in the spring I had to disconnect the pump from the well and used it to pump out my basement - it was an emergency - in the process the pump sucked in all kinds of debris). How easy/difficult is it to open the pump and clean the nozzle? Related question - is it worth the bother? I'm thinking of buying a new Little Giant JP-050C pump - I believe this is a better pump to begin with - and it has a port though which the nozzle can be cleaned. Any advice? Best wishes - John
  • 10,865 Answers
Hi John. You can definitely check the impeller in you Simer. IT is made of plastic so if u were using it as a trash pump chances are you broke off some of fins which greatly reduces the output. A new impeller is not hard to install and is about a $20 dollar part. J.
Posted on Sep 11, 2010
Pumps water for a minute then shuts off.
Probably the pump has a water pressure protection switch. So it will not run dry and burn up. How is it that you are losing water pressure? On the delivery end or receiving. Restrictions on a pump always are placed output
Jun 01, 2015 | Craftsman Professional 3/4 hp Hydro-Glass...
Why dont i have water pressure after my pump cycles off
Make sure your tank is well pressurized and not water logged.Is there a significant difference between your cut in and cut off pressure.Check for leaks -water or air.
Sep 07, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Can i use a 1" suction an 3/4" discharge
Yes, Actually the larger suction will provide better water flow to the jets and help your pump operate more efficiently.
Rod
US Parts Center
Apr 18, 2013 | Pool & Spa
Loses pressure after a couple minutes
do u hear any leaks wn its at full pressure from hose or connections. a lite soapy solution sprayed on connections will find leaks UNPLUG FIRST! also listen 2 compresser head 4 reed valve leak . Poss air cleaner dirty
Apr 28, 2012 | Simer 2802E Shallow Well Jet Pump & Tank,...
Shallow well and deep well packer installation will not stay primed
Do you have a check valve installed? If not, your water will be flowing back down the well and taking the prime with it.
Jun 21, 2011 | Simer ACE5C ACE5C Pump 1/2HP Deep Well...
Pump will not pump water, its runs
Hi and welcome to FixYa. I am Kelly.
If this is a new system installation there can be a few reasons for the pump not pumping water.
1. The most porbable cause is that it is sucking air on the suction line. Check to make sure each and every connection it a good sealed connection.
2. The pump having never had water in it may have to be primed by introducing water into the outlet hole or remove the impeller housing plug and prefill the cavity with water.
3. There should be a check valve or a foot valve with screen at the very end of the suction tube.
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/agdex1143
Limitations
Jet pumps lose efficiency as the total lift increases. Total lift includes the vertical distance from the water to the pump plus the friction losses in the suction line and foot valve. Shallow well jets are not practical if the total lift exceeds 5.5 m (18 ft).
Pumping water containing sand will cause wear and leakage around mechanical seals. The mechanical seal on the pump shaft is water lubricated and water cooled, so the pump should never be run without the pump casing being filled with water. Air or gases in the pump will cause a loss of prime. Shallow well jet pumps must have either a check valve or foot valve installed on the suction line to maintain prime.
Foot Valve:
http://t3.gstatic.com/images?q=tbn:21SLW7C9NsXXdM:http://ecx.images-amazon.com/images/I/518Frco3KaL._SL500_AA300_.jpg
Check Valve:
http://t3.gstatic.com/images?q=tbn:xIVfmPrrsgzS-M:http://www.plumbersurplus.com/images/prod/1/577733-BCV-1-L.jpg
You can use both if necessary but usually only one is required. The in-line check valve can be closer to the pump.
I will post troubleshooting if the site will accept the steps next post. Currently it says I have exceeded maximum length.
Thanks for choosing FixYa.
Kelly
Aug 16, 2010 | Flotec Corrosion Resistant Shallow Well...
Water is coming from well to pump, but pump will not pick up the water when trying to prime
If well is too deep for the pump, sometimes a foot valve is needed.
ALSO check that there is no back pressure on the output side.
Oct 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
142 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Boyet Soriano
Boyet Soriano
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
