Question about Craftsman Tools & Hardware - Others
Craftsman thickness planer mod.no. 351-275210. looking for instructions to set up or replace cutter knives.
  • 905 Answers
Are you sure that the model# 351-275210 is accurate? Sears Parts Direct is not listing this particular number. This may be because it is inaccurate, or the planer that you have is no longer supported. Searches on the internet have yielded little information as well.
If this model # is accurate, then you will need to contact your nearest store. They should be able to order you a manual, perhaps even print you one while you wait if the document is available. The store databases will sometimes have more information available than what is available from their website.
Please confirm the model #.
Posted on Sep 12, 2010
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
Planner feeds but won't cut
The knives may need to be adjusted further out, or they may be badly dull, or they may be worn too far to be resharpened, or the cutterhead drive belt may be broken.
Jan 14, 2014 | Craftsman 1212 in Thickness Planer
WHEN PLAINING A BOARD IS COMING OUT WITH A UNEVEN PLAINING ON THE ENDS OF THE BOARDS ABOUT 3" TO 4" FROM THE EANDS.
this is normal with all planers, when you feed the board in the planer there are two feed roller one on each side of the knives so you get uneven pressure on the board at the start and at the end of the board .when planing boards for a project always add 10"inches or more extras then cut to lenght after planing to thickness required. never cut boards to length before planing .
Apr 11, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
I need instruction manual book of DeWalt DW 735 planer to replace the blades
Hi mmh9894,
You may view the manual. Click the link below.
http://lib.store.yahoo.net/lib/tylertool/DW735m.pdf
Hope I help you.
Have a nice day!
Thanks for using Fixya.
Feb 24, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
How do you change the blades on a dw734 planer
Did you save the wrenches for the blades and the setting gauges? You need them. It is hard to do without. You have to take off the dust cover, should be called the finger cover, get the cutter head to lock up, it should have a pin on the right side to lock it from turning, loosen the jib screws,(bolts), and blow out he cutter head. Leave the adj screws where they are. Then do the other side, sharpen the knives, or get the new ones ready, don't answer the fone, or eat dinner at this time. The knife setter sets each knife to the same height and/or depth across the cutter head. It is a small C shaped thing that rides on the head and grabs the tip of the knife when it is at the right depth, they all have to be the same, and they just scrape the knife, they don't pull it or move it, it just touches it. Snug up the jib screw, and move to the middle, check and adj the height snug up the screw, move to the end, do the same, go back to the other end, check it again, use a small piece of wood to tap it down if you have to move it, when it looks good, torque it down, then do the other side the same way. I hope this doesn't have those tiny 2 sided knives in it? They are the worst, they have no meat, they don't cut worth a flip. You need the big knives, something with some meat to them. Check it out, hope this helps.
Jul 17, 2010 | Dewalt Planer (DW734)
I am looking for either replacement knives for a powermatic model #225, 24'' thickness planer with a quiet head which requires 36 knives, or an aftermarket replacement head with indexable cutters. Anyone...
Frezite of Portugal have agents in the States who will be able to assist you. Their products are very good, although not cheap, but are longlasting and hold their edge. I use them in my wood manufacturing business on all my machines.
Jun 14, 2009 | Tools & Hardware - Others
Thickness planer
I was able to make a knife setting jig for the Delta planer using magnets and measuring the old knife setting height abouve the knife holder before I removed the knives.
Mar 23, 2009 | Delta Tools & Hardware - Others
Uneven thickness when planning
Surely you have some mounting screws for the Knives, don't you? You may have to loosen those and Re-set your Cutter Depth & Level. I use a "Step-Gauge" to do that with. In some Rare Cases you may have to shim to attain the desired results.
Jan 10, 2009 | Ryobi Thickness Planer Blades
Tools & Hardware - Others Logo
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jim London
Jim London
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
