Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
We have just had the MSZ-GE12NA installed and it was working at first (installed on Thursday). Yesterday the outside unit froze up, after dethawing and turning back on again, the cold side of the unit had 45 degrees, the hot side was at 83 degrees, but all 4 lines going to the inside units were registering 72 degrees. When the inside units are off, it the inside unit cools down to 35-40 degrees but when you turn them on, the air coming out is now only 72-73 degrees.
  • 144 Answers
Doesnt sound like the compressor is running it may be a bad capcitor are the coils clean and do you change the filter often as you should
Posted on Sep 11, 2010
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
How do I clean Mr Slim MSZ 24NA
usa.mylinkdrive.com/.../MSZ-MSY-A09-24NA_GA24NA_Service_OB
Sep 19, 2014 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
WATER DISPENSER ON GALAXY SIDE BY SIDE REFRIGERATOR DOESN'T WORK
Sounds like if your ice maker is still working, you're having an issue with your filter maybe freezing. Check to make sure your water filter isn't froze. What you're talking about with the overflow is a coincidence, but unless the internal wiring for the unit inside of the dispenser got damaged, i doubt thats the reason why. It's either a frozen filter or bad water valve. Try dethawing the filter or taking it out and seeing how much pressure there is built up in it. There's also a water reservoir in the back of this unit that may be froze too.
Nov 27, 2013 | GALAXY Microsystems 25.4 cu. ft....
Mitsubishi Mr Slim MSZ-A12NA-1 my outside unit is not communicating with the inside unit.It will run for about 1-2 min and shut off. Help
Low freon levels can do that. Any storms lately? Could be a bad control board. Damage to wiring between units.
Sep 25, 2013 | Heating & Cooling
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Condensate drain sucking sound
Sounds like a dirty float switch, making the pump work when there isn't much water in the trough. If you can remove the central fan there is a panel in the corner that unscrews. The pump and float switch are in there. Wear a dust mask - it'll be pretty dirty in there!!!
May 17, 2012 | Heating & Cooling
We have a far-let LED flashing 1 second on 1 second off repeatedly indicating a communication error between the indoor and outdoor units. The practical outcome is that the outside condenser doesn't kick...
Call Mitsubishi Tech. directly...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 03, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
Inside unit turns on, outside doesn't
Could be a wiring problem or a lack of refrigerant. All you can do is professionally have the unit checked and serviced.
Hope this helps I take the time to answer your question so please rate me
May 22, 2010 | Mitsubishi MSZ-A15NA Split System Air...
FREEZER WORKING BUT FRIDGE NOT
Remove the rear panel in the freezer and see if the evaporator coils are frozen over.
If so dethaw coils with a hair dryer.
Reassemble freezer and set controls to the normal position.
Although you replaced the defrost timer if the coils were frozen over in the freezer no air can transfer to the ref. section from the freezer.
If you do not want to dethaw the coils unplug the ref. for 1-2 days and leave the doors open .The coils will dethaw by then.
Jan 17, 2010 | Kenmore Refrigerators
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
206 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
