Question about Hunter 23852 Classic Original Ceiling Fan
I found my Hunter Original fan's switch to be frozen, so I went in search of a replacement. I bought a 3-speed switch with similar wiring (red, blue, and black wires). I wired it up and turned it on. The speeds were in a peculiar order: slow, then fast, then intermediate, then off. I soon noticed a burning odor in the room, turned the fan off, and touched the body of the fan. It was very hot. I killed the power to the fan and began cooling the fan with a small room fan. Now, I am wondering if the new switch is the culprit, or if the fan motor is burning out (it spins freely, but hums), and is burning out the switches. What do you think?
    Scholar:
  • 57 Answers
You got the wrong switch for the fan. The fan was 2 speed before, right? Well. the Switch you bought while it being three wire and the same colors as what was in the fan before, is not the same switch.
The new switch, at some point (when you smelled burning) activated both low and high speed in the motor, drawing double current, overheating the windings. Your motor MAY be ok, but I would personally not trust it anymore without getting a motor shop to Megohm the winding to check it for insulation quality. (The fan is worth it)
Your original switch functioned as so... L 1, L 2, off. or alternatively (if it was the metal leviton switch) off-high-off-low. Your new switch was designed for use in a lighting kit... L 1 L 2, then L 1 2. In a light kit, you would turn two bulbs on, then the other two would come on, the first two shutting off, then all 4 would come on. This is why your motor is now likely burned out.
Call Hunter... 901-745-9222
Posted on Oct 16, 2010
  • 96 Answers
I think you have the power wire mixed up. Your power supply to the switch should be black. And in most cases goes the the L-1 labeled on the switch. If you have trouble finding the power just plug the wires in and use a simple light or voltage tester. Once you have the power wire just touch each wire 1 at a time and you can tell the speeds. Once you have the speeds hook them up to low being 1 med.2 high 3. Then your done
Posted on Sep 12, 2010
How do I replace pull chain on old hunter fan. No replacement available Home Depot gave generic switch. I don't know what wire color goes in switch L 1 2 3 Wire colors are red black blue
If that's a two speed hunter, you have the wrong switch. You need to get a two-speed switch. This switch comes with the wires attached. Do you have the fan model?
Mar 15, 2015 | Hunter Dryers
My old ceiling fan capacitor has A B C D on the back , the new capacitor has 1 2 3 4, how do I connect the new one????
I just changed out an old ADCB (172-90-001 / 1-81-M) fan speed switch with a L123 3 speed switch (Westinghouse 77286). My fan was only 2 speed but the 3 speed switch was all the Home Depot had in stock. So I knew I would have OFF occurring twice in the pull sequence. Its an old Hunter fan that came with the house.
A-Unused
B-Went to 1 (Blue Wire)
C-Went to 2 (Red Wire)
D-Went to L (Black Wire)
I originally put B (the Blue Wire) into spot 3, leaving 1 unused. But that made the pull order go OFF-OFF-LOW-HIGH.
So moving the Blue Wire to the 1 slot resulted in OFF-HIGH-LOW-OFF
Hope this helps!
Apr 01, 2012 | Dryers
I replaced the 3 speed fan switch on my Hunter 21834 ceiling fan/light. The fan only has 1 speed (fast). What did I do wrong? I tagged each wire to match up, but now only one speed.
What was the original reason why you changed the switch? Sounds like you got the hot wire and high speed wire swapped. The hot wire coming from the upper part of the fan should go to 'L' and then the three other wires going down to the little black boxes for the speeds should go to the corresponding 1,2,3 on the switch.
Sep 05, 2011 | Hunter 52" Ceiling Fan With Light
MY HUNTER ORIGINAL RUNS THRU AN ORDINARY WALL SWITCH. IT HAS HI AND LO SPEEDS ON THE HOUSING, BUT EVEN LO SPEED IS A BIT TOO FAST AT TIMES... HOW CAN I CONTROL THE SPEED THRU FULL RANGE... A RHEOSTAT...
Jim,
You have a special fan there. Hunter Originals are my specialty.
There are two ways to accomplish a slower speed with this fan.
1. A wall variable speed control, solid state, rated for 3 or more amps, regular fan controls will not work as your fan draws 2.5amps on high, not even new ones that are labeled for the Original.
2. Retrofit the fan to make it a three speed. If you're good with wiring, it's really simple. What you need is, a standard 3 speed pull chain switch, not a double pole one like cheaper/new fans have that use capacitor speed control, we are using cap. speed control, but not the same way they do. So you want an "SP3T" switch. You also need an 9 10 or 11 or 12 MFD capacitor (depending on how fast you want your low to be 8 is 20rpm, 11 is 75 approximately). You will remove the switch cap to your fan, and you will find your switch has a black, blue and red wire connected to it. Remove all wires, attach the black to L on your new switch, attach blue to 1, then you need 2 extra pieces of wire. Stick one wire in 2 and the second wire in 3. Now, get your capacitor and hook one side of it to the red wire and position 2, then hook the other side to the wire you put in position three.
Remember to get the Single pole switch for non capacitor speed control fans, if you get the double pole, both winding sets in your fan will be activated, which will draw double current and burn your motor out.
2speedorignial.png?t=1296263478
Also, are you aware that your fan uses oil (like an engine) ? and is not permanently lubricated?
Jan 08, 2011 | Hunter Ceiling Fan Control Switch
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
Hunter 23852,L-black to red-hurricane speed,black to yellow-almost hurricane,black to gray-very slow,hardy moves air,installed westinghouse 6A125vac switch,same speeds,how can i get a comfortable medium...
Howdy,
Sounds like a good ol' American made Hunter Original to me. BEST and most powerful residential ceiling fan (high quality) ever made. The RPM spec is 200-160-50 for the respective speeds, moving 10,500 CFM on high speed. Most ceiling fans barely crack 5,000 CFM. they were built for Brute Force Air Movement and they really don't do well for small spaces. The best solution I have for you is if you have a Wall switch for this fan, to install a Hunter Original Wall control or remote control. http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=hunter+original+control&_sacat=See-All-Categories
Both controls will lower the Medium speed to about 100-110 rpm, which should be much more comfortable for you.
Because the Hunter Original (I know your fan is an American made unit by your wire colors) draws more current than other fans, the Original controls are the only controls that are designed to work with your fan. Other controls do not have the current capacity for the Original motor.
Also, are you aware your fan uses oil?
Aug 22, 2010 | Hunter 23852 Classic Original Ceiling Fan
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Hunter 23852 Classic Original Ceiling Fan Logo
344 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
