Question about Kyocera CS-4035 Copier
How to install toner kyocera 4035 - Kyocera CS-4035 Copier
  • 113 Answers
Open the front cover. lift up the blue lever and pull out the black container. replace with a new one. pull the colorless container for the waste and replace with a new one.
Posted on Sep 13, 2010
NOT ADDING TONNER AUTOMATICALLY
hi, there
if the toner does not adding automaticlly by the machine itself press 1087twice then type the code 130 that should riplishing the toner .if that does not work type 30 and chick the toner motor
Dec 05, 2015 | Kyocera Mita KM-4035 Printer
How to service grid charge in KM 4035
make certain that the main charger that is cleaned after replace toner is pushed back in > behind waste toner bottle.
Jul 23, 2014 | Kyocera Mita KM-4035 Printer
Add toner always show copy not print and ready
When the toner supply belt is broken or displace than toner not supply from the cartridge in the DV unit.You shuld check this drive section and replace new one.I wish best luck.
Oct 26, 2013 | Kyocera Mita KM-4035 Printer
Kyocera KM 4035 driver installation failed. I get message "one or more software installations have failed."
I had the same problem "One or more software installations have failed", until I realised the Kyocera driver download was a zipfile, and I'd tried running setup from Windows explorer's extension (zipfile preview). When I unzip the file, then run setup, setup finds its supporting files and I no longer get the error. Doh!
Oct 25, 2012 | Kyocera Mita KM-4035 Printer
When I make copies from my kyocera cs 4035 the copies are very light or transparent could this be the drum?
It could be developer and it could be toner, first try to shaking the toner or put new toner, if it does not help, try refresh the developer. if you increase the density and it comes ok! this means is not the drum unit.
How to refresh the developer:on the panel: hit 1087 1087, this will take you to the service mode.press on the panel 130 and press the Start Button.select dv refresh from the screen,then hit Start again, the screen numbers start change, it will take about 5 minute or more until it finish.
To exit the service mode, hit reset two times,until you see the screen has zero numbers, and then hit one then start button.
This should takecare of your problem,
Dec 30, 2011 | Kyocera CS-4035 Copier
We have a Kyocera KM4035 copier. Do any plastic strips need to be removed prior to placing the toner cartridge in the copier?
Kyocera toners usualy have red/orange coloured tabs which should be removed prior to fitting. The Kyocera Mita web sites often have instuctions on fitting, the Austalian site is particulary good for tthis type of info.
Aug 18, 2011 | Kyocera Mita KM-4035 Printer
Kyocera km 4035 always add toner
It sounds like you may have a bad toner.
May 20, 2011 | Kyocera Mita KM-4035 Printer
I have a problem with my kyocera 4035.i dont know how to open the toner's box.
Open the front cover. Lift the blue lever and pull out the black toner container
Jan 05, 2011 | Office Equipment & Supplies
How do I make my kyocera mita 4035 printer print without the need of pressing go
change paper size from printer properties maybe the paper size is LTR so you have to change it to A4
May 21, 2010 | Kyocera Mita KM-4035 Printer
Light copy on KM 4035, KM 2035 even the spare parts inside was new.
if copies and printouts are the same then do the following... if only copies then change your scanner lamp
make sure you are using kyocera toner... empty developing unit and run sim mode 131.... make sure that you have changed the transfer assy.... thats the black roller on the door... also play with sim mode 101....
May 14, 2009 | Kyocera Mita KM-4035 Printer
Kyocera CS-4035 Copier Logo
126 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
