Question about Bose 3 2 1 GSX System
My Bose AV 321 has only started playing the right side of the system. I swapped the cables and both speakers work, but only 1 side. I have also swapped cables and the same result.
The SAME EXACT thing has happened to mine!!!!! Does anyone have an answer for this? Surely the wire couldn't have failed and can a channel on the amp really burn out? I don't blare my system at all and ggggrrrrrr!!!!
Posted on Sep 13, 2010
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
No sound in left side speakers
Swap the left and right cables to see if it's in the Bose or in the TV.
Nov 28, 2009 | Bose Lifestyle 48 System
I an lg47 240 hz flat screen hooked to a bose 3-2-1. I got the dvd to play through the bose and sound working through both the bose speakers and tv speakers, but when I try to get the tv to play through...
if you are using a hd reciever make sure the audio output goes directly to the bose system... if you do not have an hd reciever make sure its audio out on the television that you are using if you do have it hooked up right make sure the bose 321 is on the right input such as audio in!!!
if it still is not working exchange it.
Nov 18, 2009 | LG 47LG60 LCD TV
Audio problems with Bose 321 system
Hi, sounds like the centre front speaker is disconnected. Check the wiring on that, if all is good there then a fault most likely with the amp. To make sure try connecting a different speaker to the centre channel just for test purpose to eliminate a speaker/cable fault. Best of luck
Jul 11, 2009 | Bose 3·2·1 II System
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Bose Model 321
the bose will not play anew dvd comes up need paasword
Aug 08, 2008 | Bose Wave Radio
BOSE 321 GSX
1st thing I would try is to connect a different speaker to right output...if it works, that eliminates speaker problem. Then swap red and white audio input cables and hook them up backwards- connect red cable to white on both ends, and white to red...cable could be bad internally. Also try hooking another source to inputs, could be blown channel.
Jan 20, 2008 | Bose 3 2 1 GSX System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Bose 3 2 1 GSX System Logo
77 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
