Question about HP Computers & Internet
Do we need a new graphics card for a monifor that is going to sleep? The monitor (an HP that came with the computer) doe not work and wonder if a new card will correct the problem.
  • 734 Answers
Your monitor does not have graphics origination hardware so much as input recognition of the video card in your computer tower.
Borrow a monitor from a friend and see if your computer displays normally on it. If it does, you need a new monitor. If it doesn't, your computer needs a new video card or has other motherboard issues.
It's just that simple.
Best Regards
Posted on Sep 11, 2010
Pavilion p7-1148 PC with HP2301 monitor goes to sleep during boot up
hello anon..
why not test the monitor on another PC to prove which box is bad
the mon or Pc.
simple no?
NO OS stated. be nice to know which of 20 OS it is. Windows something is my wild guess. but there are so many, now.
the monitor will always tell you no sig ,
one PC first. this gets the VGA chip alive first. with all sigs
then turn on the Monitor ,if those sigs are missing the monitor always tells you they are, and will not lie to you.
that monitor is newer. not relic, and new monitors never do self sleep like in year 2002. there is no internal sleep on your monitor
it only sleeps on DEMAND, from PC VGA card (lets to VGA ok>?)
simple is easier to troubleshoot.
the 2 sync lines do the sleep mode per VESA spec.
I bet the monitor tests prefectly on any other PC.
I bet.
so lets go from that fact, and work the PC end. make sense?
ok so the VGA chip is BAD.
right, but what can make it bad even when not BAD really.
answer lots, but wait , ive no idea at all what you have.
p7-1148 PC is a desktop
and many desktops , vast, have 2 video chips
one on the MOBO and one in the PCI slot.
i cant see your Desktop rear so must go wild guessing now.
the first thing i do with any older PC is clean all that lint out.
after all if the VGA chip overheats or CPU they shut down.
all do. every one. made does that overheated.
HP has full support page on this nice PC. Decktops are my joy.
im reading your product spec, now. online at hp
it tells me this PC comes with many options video cards etc.
so Ill not guess now. that. (I open the case and look is what I do)
it has option HDMI card there, ? does yours?>
here is your graphic page
Integrated video is not available if a graphics card is installed.
  • Radeon HD 6370D, 6410D, 6530D or 6550D Graphics (model dependent based on processor)
  • Supports PCI Express x16 graphics cards
  • Two DVI-D ports (Both ports can be used at the same time)
the above means, that you are using ON BOARD VGA or
the VGA Card.
which is it , the one you use is failing.
if a card remove it and use the OTHER VGA JACK (onboard)
test that.
so open the case per online manual.
see 2 fans, make them clean,
make heat sinks lint free.
now that it has Fresh air we see if the PSU works.
if the PSU is ok,
diagnosis is serial process, i check the coin cell on each i touch.
after lint removed. 2.9vdc min, new is 3.3vdc.
then i gander at that PCI video card, is the aux power jack fell off?
black yellow wire set, if present , all fast cards have that.
then the video card GPU chip see that, see if the heat sink on it is clean? and i fitted with a fan does said fan work?
like that.
beyond that , is more test, ill stop here, most here fear opening case.
see upgrading guide here, for access to pc,
https://support.hp.com/us-en/product/hp-pavilion-p7-1100-desktop-pc-series/5146449/model/5163175/manuals
Sep 07, 2017 | HP Computers & Internet
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
Monitor goes to sleep when I turn on my computer replaced the monitor replaced the graphic card replaced the cord from the monitor still goes to sleep sometimes it will start but then freezes up then back...
If it works intermittently then it's either a loose monitor data cable, loose monitor power cable, or loose graphics card. When you say it freezes up, I'm thinking most likely your graphics card is loose, make sure you screw it tight to hold it securely. The power must be off in order to be working with a graphics card. Also ground your body's static electricity to a non-painted piece of steel such as a desk to prevent shocking expensive hardware.
Jan 13, 2012 | HP Computers & Internet
My Hp A6252D monitor keep turning to sleep by showing the message ' monitor is going to sleep' before it was turned off, but processor was still running. Sometimes, it hang and i hear noise from CPU. May i...
in power set up in control panel,there are setting for the computer and monitor,the setting is { shut down after 5mins,10 mins or never click never.and it should stay on
Jul 07, 2010 | HP W19b LCD Monitor
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
Monitor went to sleep and won't wake up
It sounds like a driver issue, but more likely the monitor driver, not the video card, since the other monitor works properly.
If you go into the video properties, check the monitor settings. You should be able to switch it to a generic monitor. You also need to make sure that you have the correct monitor refresh frequency set. If you have a mis-match, the video card could send signals at a rate the monitor can;t handle, which is why it won't "wake" even after a reboot and might need to be unplugeed to get it to come back on.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
Hp computer monitor
Hey, the problem you are getting is caused by the pc, when you switch on the pc it sends a signal from the graphics card to the monitor to come off sleep mode and display a picture,
it could be the graphics card, or memory or something more serious,
would try taking out the graphics card and memory and putting them back in see if the machine starts up.. works most of the time..
All the best
John
Jul 26, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
I cant get the monitors resolutin at 1440x900-60Hz and the monitor keeps going to sleep
your graphics card doesnt support the resolution that your monitors native resolution is set at.
btw, what graphics card are you using?
Nov 23, 2007 | HP Compaq WF1907 Monitor
Computers & Internet Logo
181 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
