Question about Craftsman Lawn Mower Ignition Switch Ayp 163968
Craftsman 16hp model 917.270670 will not start with new battery. it will start with jumper cables every time, but will not start on its own.
    President:
  • Craftsman Master
  • 1,545 Answers
You will find this odd, but the engine may need the valve clearances adjusted to cure this problem. These engines have a built in compression release which is operable at engine speeds 300 rpm and lower. The compression release makes it easier for the engine to turn over during startup and also relieves wear and tear on the starter. Most people don't know of this, and even with a new battery, the built up compression can stop the engine from turning or severely slow it down.
Adjusting the OHV system is relatively easy and there are many tutorials and even YOU TUBE videos showing exactly how it is done. They recommend you do this once a year to keep things in order. Until you do, grasp the top of the engine and turn it backwards by hand until you feel it undergoing no compression...then where it gets tight, stop turning it and try to start it.
Please vote on this solution.
Posted on Sep 11, 2010
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 16hp ohv will not start
You may have to prime it by putting a small amount of gas directly in the carb
Jan 28, 2013 | Garden
ENGINE WILL NOT TURN OVER, EVEN WITH A FULL BATTERY CHARGE AND JUMPER CABLES. THE STATER ENGAGES AND THE FLYWHELL TURNS ABOUT 1/4 REV. AND STOPS. IF I MANUALLY ROTATE THE ENGINE MORE THAN 1/4 TURN (PAST...
I am betting you will not believe this, but, your battery is bad. I just had the same problem last month. Same, same. I have always had good luck with jumper cables, but there was something wrong with the mower battery. When I removed it and replaced with new one, everything is as new.
May 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman 15.5 HP 42"
Hi government32, seeing how you just installed a new battery I'll assume you cleaned all the connections. Not cranking at all sounds like 3 possibilities, Key switch, starter solenoid, or starter. Lets check starter first. Using a jumper cable, jump from positive battery post to starter motor (you'll see the connection on the motor where cable is connected,thats where you hook jumper), if it cranks the starter motor is ok. If it doesn't thats the problem. If it does crank check the starter solenoid, using a jumper cable jump across from side to side (the 2 big terminals). If it cranks now the solenoid is bad or the electrical connections are dirty. There are also 1 or 2 small connections on solenoid from the key switch, make sure they are clean. If these 2 components check out the key switch is bad or the connections on it are dirty. (its usually not the switch).Hope this helps you.
Jan 03, 2011 | Garden
My craftsman lawn tractor quit while cutting heavy grass. wouldn't restart..........pushed it to the garage............ took off deck......... still woundn't start replaced battery ......... still will...
Try using jumper cables and jumping from the positive battery post to the starter lug where the main cable hooks to the starter. If you don't have jumper cables find the solenoid on the inside of the right side panel. Pull the rubber caps off and jump that with an old screw driver if the engine turns and starts on either occasion it is the solenoid. Part # 192507 sells for about $15.00 at searspartsdirect.com
Oct 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 16hp B&S, 42 tractor. engine surges, blows oil
SOUNDS LIKE YOU HAVE A AIR LEAK AND SOME BAD GAS AND YOU MAY WANT TO CHANG THE OIL 1 MORE TIME LETME KNOW IF THIS HELPS IF NOT ILL DIG IN TO IT WITH YA
Oct 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a B&S 16hp electric-start engine. Battery was dying for long time, finally replaced. Can't seem to get it to even turn over now. Checked battery- good. Even assumed I was wrong and new...
i would check the solenoid first if that doesn't work check starter also what you can do is turn the key on & run jumpers from car or another battery ground on engine block of the mower & take the positive & touch the bolt that the positive wire goes to on starter it will cause a spark but if starter turns over & starts then it the solenoid
Jul 04, 2009 | Garden
Craftsmans31c707 16hp riding lawn hard to turn over wont start
i had the same problem ,replaced the battery,and starter
turned out the muffler was plugged with a wasp nest,also ended up re-adj the valves later on!!!
Mar 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor turns against its self
Sounds like the flywheel key may have started to shear and changed the timing. pull flywheel and check key.
Craftsman Lawn Mower Ignition Switch Ayp  163968 Logo
456 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
