Question about GE PSW26SGRSS Side by Side Refrigerator
GE refrigerator making a high pitch sound. I've already cleaned the bottom of the refrigerator but the sound is stil there even louder. Sounds like air passing through a crack in a window.
SolutionGuy
  • 331 Answers
SOURCE: GE SIDE BY SIDE REFRIGERATOR
Kay, these are known for having faulty evaporator fan motors (failed motor bearings). This is what has failed in your fridge. This is a tedious and time consuming repair, you may want to purchase the evap motor and hire someone to install it for you. Just one of the reasons I recommend this is that 50% of the time, the new motor's wiring harness will not match the harness on the fridge and so must be converted to adapt. The evaporator fan motor is the fan inside the freezer, behind the back panels. If you choose to repair it yourself, UNPLUG THE FRIDGE FIRST! Then remove all items from freezer. Remove all shelves and bins. Remove the ice bin. Remove the lower back panel. You should be able to see the motor now, but you can not access it yet. The motor is mounted in a plastic shell/housing, this entire housing must be removed (along with the related wire harness). Install the new motor and rebuild the unit. This doesn't sound like much, but since you've not done one before, figure 2 1/2 to 3 hour job time. (With practice, it still takes us ~50 minutes) Wiring is CRUCIAL! Take note of EVERYTHING and the way things are routed in there. Otherwise, you won't know if you did it right until you have it rebuilt and plugged back in, if something were mis-wired... you'll know it now. Then have to disassemble to locate the problem. The part number you'll need is #WR60X10185, and sells for ~$45.00 at your local appliance parts retailer. If you hire someone to perform the labor, they won't be able to "soak" you on the part price. The good news is that after the repair is complete, your fridge will cool better AND I've never had a callback on these! (Which means that the replacement motors are MUCH better than the original factory installed ones.)
Posted on Aug 11, 2007
  • 5 Answers
SOURCE: High pitch noise from GE Profile Refer
get your cam corder and record it show it to your repair man
Posted on Mar 24, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Posted on Mar 23, 2009
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Posted on Apr 30, 2009
iwillfixforu
  • 619 Answers
SOURCE: High-pitched alarm-like sound coming from GE frig - TBX22PRYCRAA
Very common problem is the evap fan located in the freezer section is the cause. Sorry but this is controlled by the main board on the back and only way to fix the problem is with a new board. Sorry about the news but it is the problem.
Posted on May 31, 2010
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
I just installed a new GE MWF filter in my refrigerator. Now, after a few cups of water, it's emitting a high-pitched whine when we get water. And the water volume goes down. Is the filter defective?...
It sounds like that may be the case and thier is something wrong with that filter..do you still have the old one to put it back in temporarly and see if it works as it used to beofre changing filter
Gene
Aug 23, 2011 | Refrigerators
May 31, 2010 | GE PFS22SISSS Stainless Steel French Door...
Magic Chef refrigerator makes high-pitched whining
well u need to get it check by any expert throughly u need physical assistance u have done much.
Jul 25, 2009 | Magic Chef CTB1821AR Top Freezer...
High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Mar 15, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
GE PSW26SGRSS Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
