I have a Innovair Prestige mini split and I chance the braker switch but the airconditioner did not turn on. How can I resolve this?
  • 144 Answers
You need to make sure you have power going to it and coming out of it why did you have to change the breaker it could be more serious problem inside the system
Posted on Sep 11, 2010
  • mnieves014 Sep 11, 2010
    The room have electricity but the mini split did not turn on even with the emergenci button
I have a waves airconditioner. Its not cooling well n after some time show e4 error. How to remove the error? Plz help.
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
This was googled: waves error codes
It showed a page in "images". Stated
"System abnormity" I think. Page was blurry.
Call a tech! Mini splits can be a troubleshooting nightmare! I think its a Fujitsu unit. It would help, and may save you some $$, to call around to find a technician who has worked on mini splits. And maybe find them a 1-800 # that is their tech support # before hand, so if the tech needs it, you have it. E4 is a vague description for a fault. Make sure you have cleaned air filters, cleaned o.d.coil (turn off power at breaker 1st). Changed batteries in remote. Work safe!
Jun 20, 2015 | Heating & Cooling
My air conditioner give e3 error in turning on?
Mini splits are complicated. It sounds like it could be a humidity sensor or possibly you circuit board. Best to contact installer
Dec 21, 2014 | Sanyo 33,000 Btu Ductless Airconditioner
My innovair ac split control damaged where can I turn it On without a control?
mi remote control is damege how can turn it on with out the control ????
Jun 08, 2012 | Heating & Cooling
Help me please have a R410a 12000 btu mini split airconditioner heat pump that lost gas how do l regas it have closed all the leaks and have the R410a refregerant with the adapter.i have not charged a...
Mini splits need to have the refrigerant weighed in. First, ( if the system is already empty ) pull a vacuum down to 500 microns. Second, add the amount of refrigerant listed on the mfg. tag. Hope this helps!
Jun 07, 2012 | Heating & Cooling
Wont Turn on at breaker or fuse box.
check the braker box, and also there shold be a togle switch by the furnace that could be turned off.it sounds like you don't have any power at all
May 29, 2009 | Ruud Matching Split Air Conditioner
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
It sounds like you have a freon leak and may need a charge. When there is a leak, the compressor will run for awhile but without the proper charge, it will heat up and kick on on thermal overload. After the compressor cools, the unit will come back on. Have the unit serviced by a professional.
Jan 09, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Hi my split airconditioner is leaking water inside the house
YOU DRAIN IS STOPPED UP, FIND WHERE YOUR WATER DRAINS OUT AND CHECK THE END AND SEE IF IT IS BLOCKED OR YOUR DRAINED IS STOPPED UP INSIDE WHERE THE COIL IS.
Jan 05, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
