Question about Amana Washing Machines
Code 5d on Amana front load washer. what does this mean
futureloginn
  • 734 Answers
SOURCE: kenmore HE2 front load error 5d
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck.
Posted on Nov 12, 2008
milten1
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
SOURCE: Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Posted on Apr 03, 2010
  • 155 Answers
SOURCE: error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test.
Posted on Apr 11, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
What does code 5d mean
Hi Joyce,here's a link on your code 5d and what it means. ShopYourWay
Feb 16, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Long spin cycle of my Samsung WF8590NHM Front Load Washer is always interrupted and throws this flashing "5d" error code.
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
Aug 20, 2011 | Samsung WF306BHW High Efficiency Front...
My washer is displaying a 5d code on panel, what does this mean?
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jul 01, 2011 | Kenmore Front Load Washer
What does 5d mean when it comes up on front load whirlpool duet
5d is: It denotes suds lock (overdose of detergent dectected during the wash cycle).
Chances are you just put too much detergent in, or maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Dec 05, 2009 | Kenmore HE2 Plus Front Load Washer
Code 5d comes on and it stops running
5d means the follow; possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Code 5d
its a water senser error code check for loose wire bottom front of outer tub ,i have never had a bad one "less soap plz"
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Frontloading Washer
5d is actually Sd, which means too many suds. Make sure you're using "he" types of laundry detergent.
Jun 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
239 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
