Question about Samsung RB215LASH
A while back I purchased a Samsung model RB 215 Refirgerator /Freezer. Works well except that the ice in the bin seems to clump or stick together after it has been sitting for a while. The freezer door is seldom opened, maybe once every two weeks or so. It's in our basement and used as beer and food storage. Is it possible that the door seal is bad? Any suggestions will be appreciated
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Defrost is running too long and warming the freezer up too much...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
My ice maker on model#rf267aers keeps getting clumping together ice in the bin? Also notice Ice cycles from top area when bin is removed? how to dis assemble or what part might need to be replaced?
defrost cycle will cause ice to melt slightly and stick together. If it happens too often, it may be cycling the defroster too often. That may be caused by opening the freezer too often.
Nov 27, 2016 | Refrigerators
Why does Ice in ice maker sticks together, forms clumps. Jams, then kicks latch open
I'm pretty sure there's an owners manual section on adjusting the ICE-MAKER's fill level... (url @ bottom)
Every-other caution SEZ
"Thou shalt not RESET more often than 24 hours"
Over-filling can cause the cubes to be strongly connected... and cause clumping issues in the bin...
Also look to see that the cubes are not hollow... that is a different adjustment.
Make small adjustments... you will be happy...
Big (evidently FREQUENT) adjustment can cause more trouble than inviting the Samsonite gorilla in to SERVICE your appliance...
(I'm just saying)
http://support-us.samsung.com/nas/storage/201406271751003%5Estorage_attachment%5EHow_To_Reset_The_Ice_Makers_In_Samsung_Fench_Door_Refrigerators.pdf
Apr 05, 2016 | Samsung RF26XAEWP 26 cu. ft. French Door...
How do I fix ice maker that is dripping water from filling into the ice bin?
You will need to change the water control valve. Can you confirm the model number? Is the model LFX31925ST above your post correct? If yes this is the part=> AJU72992603 Water Inlet Valve See part location number 619-A in photo=> HERE I'm here should you have question, Thanks, Sea Breeze
Oct 06, 2015 | LG LFX31925ST Stainless Steel Bottom...
Ice maker makes ice but will dispense through door. Checked and it is not clogged.
Good day!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
I hope this information will be helpful...Thanks for using fixya...
Sep 09, 2011 | Hotpoint HSM25GFRSA
RB 215 ice maker not making ice very fast? Was great for awhile now using more ice it just can not keep up. No manual
they can only freezer water just so fast. they will not keep up with heavy demand for ice it will only harvest ice about once an hour
Apr 10, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice doesn't come out into glass. Makes some ice but is larger pieces stuck together or flat pieces in bottom of container. Green light in back of container is on. I set the freezer to colder temp but...
You are not using enough ice.
You may need to dump the bin every week or so and keep fresh ice in the bin.
When you go through several defrost cycles the ice tends to eventually melt and stick together.
Mar 10, 2009 | Refrigerators
Ice maker makes ice, but won't dispense.
if you hear a click when the actuator is depressed the swt is ok remove ice bin and try rotating auger mtr by hand if you can't the auger motor is frozen, you can remove the whole auger asm and let it thaw out and dry out for a few days
Dec 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Samsung RB215LASH Logo
112 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
