Question about Ovens
Wiring Diagram admiral stove - Ovens
Samet model 611 stove wiring diagram
Request the diagram directly from Samet.
Aug 08, 2016 | Stoves Ovens
I have an old Admiral stove, unknown model #. Black, smooth top- all else is white. Wording on the oven buttons have erased, i have no clue what degree i am setting to and or if baking/broiling. Help!
go on line and type in admiral stoves
there are pages of parts suppliers
on the back of the stove or inside the inspection plate at the back there will be a decal stating the model and serial number of the stove
Apr 23, 2015 | Ovens
Wiring diagram stove
That is an older model, so the wiring diagram will be harder to find. Have you already checked the manual? I would also suggest checking online at the manufacturer's website. Other than that, you can try online.
Elisa Jed ' http://www.atlasappliances.com
Jun 22, 2014 | Ovens
Ge stove wiring diagram
Will any wiring diagram serve, or do you have a particular model GE stove in mind?
Oct 24, 2013 | GE Ovens
Need wiring diagram univa stove /oven model ph14s
Were do I get the skimatics for a stoves wiring as I have to put the regulater back to geather as old one fell apart.
Jan 22, 2010 | Ovens
Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Dec 31, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EMa - need wiring diagram
I will give you access to the handbook shortly.
Sep 27, 2009 | Stoves 720EF Electric Double Oven
LGR3330ADB Admiral touchpad display does not work
Usually this is due to a bad main clock/electronic control in the control panel but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.repairclinic.com
https://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Jan 27, 2009 | Ovens
Schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Ge spacemaker cooking center wiring diagram
1. usually green wire is ground, connct to the body for your
stove.
2. the white neutal wire should connect to the stove neutal, one
hot wire to the stove and one to the light.
3. be careful
Jul 05, 2008 | GE Ovens
Ovens Logo
95 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
