Question about Craftsman 25cc Gas Line Trimmer
Pull cord replacement craftsman gasoline 25cc weedwacker
    President:
  • Craftsman Master
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Loosen it. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit with the pull handle installed at the end of the new rope, so if you slip holding it, all tension won't be lost.
Posted on Sep 11, 2010
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
May 10, 2010 | Garden
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Where can I find parts for a 25cc Craftsman Weedwacker engine
get your craftsman parts from Sears [1-800-4myhome]. be sure to have your FULL model number available
Sep 07, 2009 | Craftsman 25cc Gas Line Trimmer
Pull cord won't pull
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Aug 27, 2009 | Garden
Pull String Ripped out, How to Replace?
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
Jul 20, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
987 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
