Question about Ranger Communications RCI-6900F-25 CB Radio
A body projected at an angle of 30 with velocity of 49m/sec.find out its horizontal range?
    Problem Solver:
  • 14 Answers
ARG Z = V
Posted on Jan 04, 2011
Need a bullet drop chart for a 1917 eddystone 30 06 with a 26 in barrel using hornady 150gr round.
Results are really only needed for caliber, load (in grains) and round in weight and style.
    [PDF]Standard Ballistics Chart - Hornady
    www.hornady.com/assets/files/ballistics/2015-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET. ITEM #. MUZ 100 yd 200 ..... Bullet. LRN . . . . . Lead Round Nose ..... 0. -6.4 -18.8 -38.3. AW 30-06 Springfield. 150 gr. InterLock® SP. 8108. 2910. 2637. 2381. 2139.
    [PDF]HMC 07704 Ballistics Charts as PDFs - Hornady
    www.hornady.com/images/ballistics/ballistics_charts.pdf Velocity (fps) / Energy (ft/lb). Trajectory Tables. CARTRIDGE. BULLET. ITEM # ..... LM 30-06 Sprg. 150 gr. SST LM InterLock. 8519. 3100/3200. 2867/2736. 2645/ ...
    [PDF]Hornady ballistics charts
    www.hornady.com/assets/files/ballistics/ballistics_charts.pdf Trajectory Tables. CARTRIDGE. BULLET. ITEM # HITS #. MUZZLE. 100 yds. 200 yds ..... C 30-06 Sprg. 150 gr. SST InterLock. 8109. 911. 2910/2820. 2686/2403.
    [PDF]Trajectory Tables - Hornady
    www.hornady.com/assets/files/ballistics/2013-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET ...... 30-06 Sprg. 150 gr. InterLock SP. 8110. 2910. 2637. 2381. 2139. 1911. 1700.
    30-06 Ballistics Chart & Coefficient GunData.org
    gundata.org/blog/post/30-06-ballistics-chart/ Jul 11, 2012 - ... 1000 yard 30-06 ballistic charting of a Remington 30-06 Springfield 165 Grain AccuTip Boat Tail with a BC (Ballistic Coeficient) of .447 that was created using our free ballistic trajectory calculator. ... 150, -1.1424, 2499, 2288, 0.17 ... 600 Round Glock Magazine · 10mm vs 40 Summary and Ballistics · How ...
    30-06 Springfield / Hunting & Ballistics:
    www.gunnersden.com/index.htm.30-06springfield-ballistics-hunting.html External ballistics pertains to bullet velocity, energy and trajectory down-range. ... Below are several hunting ballistics sight-in charts for 30-06 Springfield ammunition that ... Ammunition manufacturer: Hornady. ... Bullet weight: 150 Grains.
    30-06 Springfield:
    www.gunnersden.com/index.htm.30-06springfield.html 30-06 Springfield Cartridge, Rifles, Reloading And Ballistics Information. ... Ammunition: Hornady 150 grain SST bullet. Bullet diameter: .308 inch. Bullet
Jan 19, 2016 | Optics
Simple pendulum
When giving physical quantities you cannot omit the units. (an angle of 10 what). You cannot solve the problem fully because you are missing the length of the pendulum.
You cannot use any kinematic relations because the expression of the period depends on the assumption that angles of rotation remain small.
You will have to use the energy conservation principle. Assuming that the mass was released with 0 initial kinetic energy, the kinetic energy at the lower point (angle 10 degrees) is equal to the change in potential energy between the release point and the point where the mass is.
(1/2)mv^2=delta Ep= Ep(30 deg)-Ep(10 deg)
Once you calculate the potential energy (see screen capture) difference you will see that it is proportional to m*g, so the mass will cancel out.
fa4a24ac-c4c2-48d5-9f73-9560389da196.pngYour turn: Calculate the potential energy difference between the positions at 30 deg and 10 deg, equate the result with the kinetic energy and solve for v^2, and hence for v the tangential velocity.
Nov 06, 2013 | Computers & Internet
Picture displays for 30 secs, goes off, then 30 sec displays again
You could have a bad lamp, a bad power supply, or a bad temperature sensor. These range from 250-300 dollars to get repaired through a repair shop, or you can at least try replacing the lamp yourself with internet prices being substantially lower.
Jun 07, 2011 | Mitsubishi WD-52628 52" Projection HDTV
A rock climber throws a small first aid kit to another climber who is higher up the mountain. The initial velocity of the kit is 18 m/s at an angle of 74° above the horizontal. At the instant when the...
Depends on how long it has been travelling. If it is horizontal when it's been caught then ot must have reached zero velocity. No matter the angle gravity works at 1m/s/s. Do the math.
Sep 18, 2009 | NorStar Operational Software Category E...
Equations of Kinematics in two Dimensions & Projectile Velocity
This is for educational use only-hacking any software/hardware is by definition illegal. so long as you are aware of this. Hello there, google these words so that you are pointed in the right direction-----dvd+jon+iphone
Nov 25, 2008 | Computers & Internet
12th science maths(derivation,vector,conic section)
This is a repair and consultation forum. Are you doing homework, or do you have a technical question on a consumer, industrial, or commercial electronic product?
Feb 25, 2008 | Televison & Video
What is the range shutter speed?
The DiMAGE A2 controls shutter speed in the range of 30 sec. to 1/4000 sec. in 1/3 increments. (at bulb maximum 30 sec.) The speed, 1/4000 sec. is controlled only when the aperture is f5.6 or over in P and A mode. The highest speed in S and M mode is 1/2000 sec. The lower range depends on the set camera sensitivity. ISO800: 4 sec., ISO400: 8 sec., ISO200: 15 sec., ISO100 and ISO64: 30 sec.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Ranger Communications RCI-6900F-25 CB Radio Logo
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
