Question about Ovens
How to switch on top oven on a belling schott ceran
3 Suggested Answers
shane_barnha
  • 136 Answers
SOURCE: Whirlpool Schott Ceran. I have no instruction book
I would try to get the manual for you but I would need your Model Number for that so here is the next best thing. Go to this site, http://whirlpool.com/home.jsp then in links along the top you will see OWNERS CENTER if you hover above that tab you will see that Whirlpool has supplied us with all the information we could need. Just click on manuals and follow instructions.
Thumbs up if I helped you!!!
Feedback is greatly appreciated!!
Good Luck!
Posted on Jun 15, 2011
  • 1514 Answers
SOURCE: I have a fisher@paykel schott
You need to give the model number to get exact instructions. On most Fisher & Paykel ovens there is a button with a picture of a hand over it. You press this button to take it off auto. I expect if yours is new it will be the same. If you need a user manual you can get one in Adobe Reader format from http://www.fisherpaykel.com.au/customercare/userguide/index.cfm
Posted on Sep 25, 2010
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
My belling wall oven model number 444440560 keeps going out after only a few seconds ignition how can I fix this thNks
which is going out top or bottom? may want to check the oven safety valve though it does not normally go out compared to other components. may have a bad igniter ( does it glow or lite up at all) it may still glow but not put out enough current to ignite flame? check with multimeter as well. if oven top is going out also check the igniter model or infinite switch
Mar 10, 2015 | Belling Ovens
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Schott ceran cooktop glass replacement
Hi, cooktop glass replacement can be found at amazon, here: Amazon com Schott ceran glass take a look. Wish you best of luck
Mar 31, 2012 | Belling Ovens
Whirlpool Schott Ceran. I have no instruction book and I find it trial and error to turn it on.Is there a book on line , Richard
Good Luck!
Jun 15, 2011 | Whirlpool Ovens
Can i install my glass top ceran hot plate directly onto my laminated bench top? Will the glass get too hot for the laminated bench top?
The edges of all cooktops, glass included, just sit on the laminated bench tops without a problem. I have never seen a laminated bench top burnt or melted.
Feb 26, 2011 | Ovens
HOW DO YOU INSTALL A REPLACEMENT TOP OVEN GRILL ELEMENT IN A XOU500SS BELLING DOUBLE OVEN
remove the appliance so you can access the back panel. Make sure it is switched off at the wall and unscrew the nuts holding the element in place. disconnect the wires making sure to remember which wire went where. unscrew the screws holding the element inside the oven and remove. Reverse process to install new element
Feb 22, 2011 | Belling Ovens
The Schott glass top is cracked - where can I replace it?
I will assume you are talking about the glass top on a range..If so they are not cheap..they range from 600.00 to 1,000 for a replacement top.
Dec 19, 2010 | Whirlpool Ovens
Main top crack do I need to replace the entire top?
Hi jerseyfol58,
Hate to say it, but yes. The entire "ceran top" comes as a whole, with the exception of the burner`s.
You might consider purchasing the top but having a pro install it, it is quite involved.
Hope that answer`s your inquiry.
Good luck.
macmarkus :)
Dec 07, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
82 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
