Toshiba Satellite P305D will not turn on. I have swapped out the battery and power cords with a known working machine and still nothing. Also took the battery and power cord from the bad 1 and put them in the working 1 and it has full charge and turns on the known good machine. and now im stuck as to why it wont turn on
  • cbhamrick1 Sep 11, 2010
    Did that still wont power on. Looks like a new doorstop for me :) thanks
    The solution was helpfull but didn't fix the problem. thanks anyway
    Genius:
  • 1,035 Answers
Hi. Try to drain the electrostatic energy of the board. Take out the battery and unplugged the power adapter. Press and hold the power button for 30 secs. Put everything back in then turn ON the computer. If still no power then this is a motherboard problem. There might be a problem to the connection from the battery going to the mainboard.
All the best!
Posted on Sep 11, 2010
Satellite - LED light on with AC power cord but blank screen and doesn't turn on
video card is the number 1 issue for Toshiba satellite models, need to reheat the mounting of the video card.
avoid disassembling the unit, what I did was.
*blow dryer (for the hair)
1.use the blow dryer to heat up the side of your Toshiba, point at the exhaust, located on the left side, do this for 35 seconds.
2.after using the blower, turn on the power button again and see what happens =D
hopefully it will work.
NOTE:
I had the same problem and it solved the issue.
Jul 09, 2014 | Toshiba Computers & Internet
Where is the cmos battery on toshiba satellite laptops
it is inside in the computer, need to dis-assemble it and you will find on motherboard
Jan 08, 2013 | Toshiba Satellite P305D-S8900 Notebook
Sound not working on Toshiba Satellite P305D-S8818. Conextant HigDef SmartAudio 221 Driver installed and updated. Device manager says it's working but nothing coming out.
Toshiba Satellite P305D sound driver
Just click on the link, select your operating system first and then download the driver; http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&moid=1998634&src=EXPL
Good Luck!
Jul 21, 2010 | Toshiba Satellite P305D-S8818 Notebook
Black screen if electrical cord is plugged into my Toshiba
Power options is most likely where you need to look to fix this. Go to the Control Panel and search for Power Options then change plan settings.
On a laptop, you will see that there are different options when you are plugged in versus running on battery.
Check your settings for blanking the screen when you are plugged in, that's probably where you will find the problem, set it for at least an hour before it blanks the screen.
Oct 02, 2017 | Toshiba Satellite P305D-S8900 Notebook
Toshiba M35 S359
This code sound like a power supply or battery depleted code.
Your Power adapter may not be charging the battery. The battery made have reached "end of life".
Mar 28, 2010 | Toshiba Satellite M35-S359 Notebook
I cannot get any response from my toshiba satellite p305d-s8828. I have plugged it in - nothing. No lights at all when pushing the start button. Help, please.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 22, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
Toshiba Satellite P305D-S8828 no charge battery
sounds like batterys not chargeing mite need new battery....or your ac power unit is not getting to the battery. lala linda
Jun 15, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
