Question about Frigidaire FEQ332S Dryer
I had a chipmunk climb into my vent and into the dryer. It was ran without knowing the critter was inside, now the dryer over heats. The top right side and the line where the wires run get so very hot. What needs to be replaced?
    Sergeant:
    Novelist:
  • 193 Answers
Something is still blocking the air flow to the outside, or the motor is burned out. Pull your lint filter out and turn the dryer on. You should be able to hear and feel air rushing through the lint filter hole. If no air is coming out the blower motor is porbably burned out. If something actually stops the blower wheel from turning it will quickly burn the motor out. Remove the back panel to access the fan motor. Be sure to unplug the dryer before removing any panels. If air is flowing at the lint filter, your vent line is stopped up.
Posted on Sep 11, 2010
2004 Mercury Mountaineer-Horrible smell coming from AC/Heat system....does not smell like coolant.......I have had chipmunks in the engine compartment. Is there an outside air inlet with a dead chipmunk?
This is not good. Your problem is worse than the Squirrels that put Walnuts in my A/C ducts and shorted my controls. The critters can chew holes in the plastic vent covers to gain access.
Your critters could have pooped and peeed in your Ductwork. This may be covered by your Comprehensive Insurance as it is a Health Hazard. Call your Agent, really, call your Agent.
I believe your Series of vehicle has an In-cabin Airfilter. This may help. Ford does carry products to Sterilize the A/C ducts which will help. Although the products were intended for Mold and things growing in the Ducts.
A dead Chipmunk is a possibility. So is a cooked animal on the motor. Good luck on this, about all you can do is change the Incabin filter and decontaminate. A Dealer can take apart the ductwork and get to th heart of the matter.
Oct 05, 2010 | 2003 Mercury Mountaineer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Electric Dryer takes too long to dry clothes. Hose/vent is not crimped or locked. How do I clean out the vent built into the wall and ends at my roof top?
Here's a trick I used on my laundromats with vertical exhaust vents on the dryers..
When the dryers began drying too slow, taking too much time, giving out too many refunds...
I resorted to climbing on the roof with a webster duster... it looks like a chimney sweep brush on a telescoping pole.
I turned the dryers on and while they were running, ran the webster duster down the vent pipe.. It cleaned out the duct very well! I got "linted" but it worked!
Remember that the vent run should not be too long. If it gets too long, it will not stay clean and it will take too long to dry as well. if this is a recurring condition, you may want to consider a reroute of the duct.
Also, the exhaust end should be free flowing... no screen. A self-closing flap is okay, but no screen..it will simply clog up the works...
Try the webster... they sell them at the local grocery store... they come with their own extension pole too!
Let me know how it goes!
k
May 29, 2009 | Oregon Scientific Electric PTO Clutch for...
Dryer getting hot but not drying
YOUR DRYER will start and run with only 110v. applied to it...........................How ever you won't get heat without 220v..........after you run dryer a few minutes you should feel HEAT inside.......my guess is you have no heat but the dryer runs,,,,,,,? If this is so, you probally are not getting 220 volts. you either have a blown FUSE or a bad circiut BRAKER in your main panel... remove cover (the small one) on back of dryer where the plug cord goes in....get someone with a voltmeter to check for 220v. going in to your dryer,,,,,,,,,,BLACK(wire) toWHITE(wire)=110v...........RED(wire) toWHITE(wire)=110v.........BLACK(wire) to RED(wire)=220v.............Let me know how you make out....P.S. don't go on ROOF..!!!!
May 11, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs but does not heat to dry clothes.
open dryer, turn it on and make shure the elements get hot. right beside or in front of it, there is a quarter sise thing with two screws. that is the thermistor. you can get it check for free most any ware. yes most likely it is the thermistor.
Mar 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not drying clothes properly
Replace the vent tubing, sounds like something is stuck or it is crushed somewhere. So replace it for about 5 dollars and see if that works. It should since you disconnect the hose and it drys right away
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Dryer operates but will not heat up.
Check to see if your venting is plugged with lint or anything else. I had placed a new outside vent cover with a screen on it to keep the critters out of the vent pipe and that screen clogged up with lint. The dryer went thru all of its operations but the heat shut off right away because of this plugged vent.
Dec 04, 2008 | Dryers
Bad heat in two year old GE DBXR463ED2WW electric dyer. Not as hot as used to be, takes longer to dry!
If you're experiencing a dryer that requires a longer time to dry, you may want to view this link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the first major paragraph. I know the link is for a no heat problem, however, if you have a dryer that is starved for air, the heating circuits will eventually fail. In most cases, a no heat, or longer dry time problem is directly associated to clogged ventilation, kinked dryer vent hoses, improperly installed vent ducting, a clogged blower fan assembly, or rodents. Yes...the last one isn't always fun, but I have found bird nests, mice nests and even snakes inside dryer vents, clogging the air flow. The symptims were all the same - a dryer that would not dry properly. Before you assume you have a component going bad, take a good look at the way your dyrer is installed and inspect it thoroughly for what might be a good cleaning. The outsiode dryer vent should be at least 12 inches off the ground and a louver is recommended to cover the end to prevent critters from getting inside. In addtion, the SHORTER nd STRAIGHTER the dryer exhaust vent is, the better. If you have an exhaust vent with excessive bends, or excessive run length, this can contribute to poor heating of the dryer. Especially exhaust vents that run thorugh an attic or under a crawl space. They typcially develop sags, which create choke points where lint can accumulate to the point where it clogs. I do not know what your situation may be, but provide this as some helpful guidance just in case. I hope you find this information helpful. If you inspect your dyer and still have problems, please post back and let me know.
Sep 03, 2008 | GE Dryers
Dryer heats up but isn't drying properly
yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Jan 02, 2008 | Dryers
Help with odor
I have had this happen 2 times. Chipmunks discovered the outdoor vent that exits through our basement window. They crawl in and suppocate in the link. You need to remove the vent hose.... take it outdoors and empty out your dead critter!
THEN, find some way to keep it from happening again.
Nov 12, 2007 | Amana NDE2335AY Electric Dryer
Frigidaire FEQ332S Dryer Logo
152 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
