Question about Garden
Just had my 1965 t-bird 4 barel carb. rebuilt. Installed it and it seems to be getting too much fuel. tried to start it and it seemed to flood right a way, I mean a lot of fuel. i let it sit for a few days, hit the pedal once real quick and it did start. ran it for about 5 minutes sounded ok idaled good ggood when I gave it some more pedal. I shut if for a few minutes tried it again and the same thing lots fuel and woundnt start. What do you think?
    President:
  • 1,627 Answers
It sounds to me like the accelerator pump should have been replaced at the time the car was rebuilt.You may want to return it to the rebuilder and ask that a new one be installed in it.
Posted on Sep 12, 2010
Why FZR600 seems to lose two cylinders while driving, carb or spark problem?
if carbs are clean and not flooding etc then try finding out which cyls are off then swop plug caps over from good cyls and see if problem moves , if yes then fit a set of 4 new plug caps ! if no then do carbs again !!
May 20, 2014 | Yamaha FZR 600 Motorcycles
Echo HC-150 rebuilt the carb, and now the primer bulb sticks and engine won't start
Try to pressure test the carb to see if you have an internal leak. If it won't hold pressure then it is junk and needs to be replaced. If it holds then double check that you didn't accidently put the gaskets and diaphragm in wrong. If it holds and still doesn't work right replace the carb anyway. They are relatively inexpensive
Jan 20, 2013 | Echo HC-150, Hedge Trimmer 20"
I have a John Deere LT 150 lawnmower that seems to flood while I'm mowing. I have replaced the filter and the coil, still the same problem. If I remove the fuel line and drain the filter, it will start...
THE NEW GAS IS ******* CARBS, IT WILL NEED TO BE REBUILT , OR JUST CLEANED, GET SPRAY CARB CLEANER, REMOVE THE BOWL AND SPRAY AROUND THE NEEDLE VALVE , FLIP THE FLOAT UP AND DOWN AS YOU ARE SPAYING IT.. DO NOT GET THE SPRAY ON THE BOWL GASKET ! IT WILL SWELL IT UP ! .. LET DRY FOR ABOUT 10 MIN ... THIS MAY WORK . IF NOT YOU MAY NEED A FLOAT AND A NEEDLE AND SEAT.. CALL YOUR LOCAL LAWN MOWER SUPPLY SHOP .. USE A GAS STABILIZER .. THIS WILL HELP AVOID THIS IN THE FUTURE .. JAY.. THE POOL PUMP MOTOR REPAIR GUY .. HIT THE YES IF I WAS OF HELP..
Jul 21, 2011 | Garden
My 300 utility seems to flood out everytime I try to start it. I have rebuilt the carb, including replacing the needle valve. After it turns over for 4-5 times, gas starts pouring out of the carb. I do not...
the needle is not seating with the float which is causing the carburetor to flood. either the needle is not attached to the float(some snap into a plastic groove, others have a spring) or the float is bad. Hope this helps Tim
May 29, 2011 | Desa International Garden
I have recently rebuilt a vintage motorcycle and it will not fire up. The ignition is set properly and a get a good spark when the plug is out. Capacitor and coil seem to be OK. I does seem to flood...
Try using a short burst of starting fluid into the carb. Don't give it gas.The object is to get it to "fire". Don't use this stuff more than once or twice. In the winter I have used it because of hard starting. What carbs are you running.. 930s? In it "trying to fire" Do you get a "bump". What year is this bike? You can also "prime" by hand with "petrol" .. just a small squirt into the carb.. stay off the throttle. The whole idea is to get it to fire and the compression from that may get the carb to work.
Have you rebuilt the carb? What book are you using?
Testing a float is easy.. stick it under water and if you see bubbles it is dust.
Flooding mean the float might not be right, I take it you have one carb.. some guys do switch the heads and manifolds.
If all fails on the old carb you can get a new PWK. The other thing I have done on my Triumphs is get rid of the Zerner Diode and Rectifier and use an electronic Selnium Recitifier. they run about $50. The capcitors (condensors) last about a yr when running points. A good upgrade is to go electronic but points work well.
Here is what they look like;
http://cgi.ebay.com/ebaymotors/BRITISH-TRIUMPH-BSA-BOBBER-PWK-BRAND-NEW-CARBURATOR_W0QQcmdZViewItemQQhashZitem4a9f9666d2QQitemZ320505013970QQptZMotorcyclesQ5fPartsQ5fAccessories
Mar 21, 2010 | Triumph Tiger ABS Motorcycles
1991 cr 250 wont start seems like it floods quick
float adjustement buddy take the carb off take the bowl off and the float and bend the tab up a tad its filling it to much with fuel and not shutting off you can tell if its done correct by adding fuel and the fuel will rush through then sudenly shut off this is the float shutting it off any more info buddy just get bac to me39c5d94.jpg
Sep 15, 2009 | Honda CR 250 R Motorcycles
1979 suski 750,bike runs on 2 left side cylinders, 2 right side cylinders are not firing, new plugs, plugs seem to be firing, rebuilt carbs adjusted, raw gas com coming from exhaust pipes on right side....
Hi and welcome to FixYa,
With the indulgence of craigjamesbt...
A few additional ideas to consider:
  • it would be an electrical/ignition issue if 1 & 4 or 2 & 3 will not fire but not 3 & 4;
  • almost always, raw fuel on exhaust indicates a flooded engine. A flooded engine would most likely be a carb issue;
  • best way to determine if it is an engine concern is to do a compression test;
  • a way to test the right carb pair is to deliberately starve them of fuel by temporarily plugging/blocking the inlet port/seat with rubber similar in appearance as to those used for glue gun, not installing the needle and float. Assemble the carb and install. Start the bike and use/spray carb cleaner on the right side carb. Note if 3 & 4 will fire even intermittently.
Would appreciate a postback on results/updates on any developments.
Good luck and thank you for using FixYa.
Apr 25, 2009 | 1979 Suzuki GS 750 E
When start bike up,it runs on 4 then onto 3 then 2 then cuts out.have stripped carbs rebuilt,balanced them.new plugs.runs fine till warm,think may be fuel problem. changed fuel tap.ballenced carbs with 2...
Are the cabies flooding or runing out of fuel? pull the choke on dose it help if it does low fuel.
Drain the bowls and see if there is plenty of fuel.....If its flooding turn the fuel off or block it when the engine starts to drop clys if it starts to pick up after 10secs or so the carbies are flooding
Feb 23, 2009 | 1988 Suzuki GSX-R 750 J
Can't keep running seems to flood out 1978/79 kawasaki
check the timing it sounds like your problem is there
Jan 13, 2009 | 1976 kawasaki KE 125
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
