Question about Ovens
The dirt will not go into the canister - Ovens
    President:
  • 2,047 Answers
Please clarify what you mean?
Posted on Sep 11, 2010
OVEN DOOR HINGE
Possible that the door hinges have accumulated dirt on the hinges or the joints within or the gaps on the hinges. Please wash off dirt and food particles , use a WD 40 to clean the hinges and try.
If not also try to remove and reset with the correct alignement after washing the hinges with diesel or kerosene and oiling them.
Dec 23, 2011 | GE Profile JT910SASS Electric Single Oven
Door not fully closing. hinges seem faulty
Look for the alignment of the door, sometimes this can be due to dirt accumulation on the sides and prevents the door to come closer. Also the hinges could have gathered dirt and so does not come closer.
Clean the hinges and see if the door requires a reset.
Jun 17, 2011 | Ovens
Cooling fan not working on 058587085
Probably went bad a lot of exhaust dirt gets in there. Make sure power is off take it out and replace it ,you can find one at your local Grainger if not they can match it up.
Apr 08, 2011 | Stoves Premier 720EMa Electric Double Oven
La Germania oven won't stay lit. Stove is 10 years old and problem just started. It will light, but goes off after a few seconds.
Use a good air gun to blow off dirt inthe regulator. dirt in the nozzle and the burners.
Use a good brush to assist, or a thin metal wire to push through the gas passage .The air mixing section must be fitting correctly wedged.
Sep 11, 2010 | Ovens
The timer has gone on the cooker and I can't use the oven or the grill
Open and check for traces of dirt in the system due to insects. Clean the printed circuit board and check if the timer works. If not you will need to install a new one for using the timer. Hope the model uses the electronic type. If manual type try to clean and reset the clock action as a last resort.It might work with a good oiling, dirt cleaning using a good cleaner like WD40. hope you try this out. Good day
Aug 11, 2010 | Electrolux Ovens
How do I clean oven
Hi
These are the things you will need to clean your oven.
Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
Remove oven racks and place them in soapy water to soak.
Preheat oven to 200 degrees.
Turn the oven off and spray the inside with oven cleaner.
Allow to sit for 10 minutes.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
    Dry with a soft cloth.
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    Jul 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven takes long time to heat up and smell gas odor
    That means the pilot flame is not directed towards the main gas orifice or tthe first main orifice next to the pilot burner is blocked with dirt
    Jul 29, 2010 | Kenmore Ovens
    Works in the winter but not in the summer. Particles of dirt come in even though the outside vent is closed.
    hello,
    All Frigidaire Electric Gallery Series carry out same function when working it pull dust that are around can not be easily see with eye (micro dust) around throngh the air ventilation when it plug on to power .
    what you are to do always after use is to clean it very well in other to avoid the accumulation of the dirt to avoid damage of element (HEAT PTOVIDER)hope this help.
    thank you and thanks for using fixay.
    Jun 24, 2010 | Frigidaire 30 in. Electric Gallery Series...
    The element won't turn off. When I turn the knob,
    Probably a broken element. It is shorting out against the element canister. If not broken and shorted. You have a bad timer.
    Jul 03, 2009 | Frigidaire Ovens
    Dirt and grease between glass in oven door
    i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
    any ideas jimmy
    Aug 01, 2008 | Ovens
    Ovens Logo
    26 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
