Question about GE JSP47 Electric Kitchen Range
Need part ge jsp47 top glass. glass broken need to replace. I need a part # and where to buy. GE profile jsp47wof5ww.
the dr
  • 447 Answers
SOURCE: Replce smooth glass cook top
Id be glad to help from my end. I would reccommend a live chat session while you are working on it so i can give you expert pointers.
Posted on Nov 24, 2007
SOURCE: Replacement of glass top
Just a note when you're doing this... when you open up the top, put a towel across each side so that when you drop a clip, it doesn't go down the side between the oven and the outside wall. If it does, hope that it goes all the way to the bottom where you can get at it by removing the bottom drawer. If you put the towel all the way across the oven box before you start taking things apart, you also won't have to worry about where little tiny screws go when you drop them... and, you will drop them! ;-)
Also, the old tops had a reinforcement bar that the ground was attached to. The new ones don't. There's a tiny hole on the flange of one of the right hand burner holes... that's where the ground is supposed to go on the new top. You WILL need a smaller self tapping screw than the original one.
And, forget having a helper... get something to prop the lid open with that won't fall if you raise the lid a little while you're working on it. Helper will just get in the way and can't hold it still enough while you''re trying to man handle those tiny little clips and screws that hold the burners in place.
--Jeff Moden
Posted on Oct 25, 2008
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
MNTECH
  • 1543 Answers
SOURCE: GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Posted on Jul 01, 2009
garing
  • 998 Answers
SOURCE: Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Posted on Aug 17, 2009
How can I tell if the touchpad is bad or the ERC is bad?
Ge JSP47 Manuals
www.manualslib.com > Brands > GE Manuals > Cooktop
... User Manuals. View online or download Ge JSP47 Owner's Manual. ... Self-CleaningElectric Ranges. Brand: GE .... Special Features Of Your Oven Control18.
Oct 01, 2015 | GE JSP47 Electric Kitchen Range
F9 error code on ge jsp47 oven
F9 Problem with door lock circuit. Check all wiring connections. If all look good replace the door lock. Here is the part to order.
Feb 13, 2013 | GE JSP47 Electric Kitchen Range
Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
Need to replace burner on ge profile jsp47
Hi pauli1598, if you are thinking of doing it yourself, let me suggest a quick look at the following link www.ehow.com/how_2262532_diagnose-repair-electric-burner-problem you'll find a complete procedure there and if you don't have a meter you can always exchange the defective element(burner) with one that is working just make sure it is defective. You can always find replacement electric elements in your local appliance parts srore or sears or if you prefer on line ordering www.repairclinic.com you will need the complete brand name and model number.
Jan 08, 2010 | GE Profile JSP47 Electric Single Oven
My GE Profile Dishwasher circa mid 1990s will not completely drain. I took the drain cage off and found pieces of broken glass and old food remnants in it. I used a shop vac to **** it all out....
Sounds like there is. It is common to find objects or small pieces of cloth stuck in the water pump. Remove the water pump and disassemble it and reinstall it. Or purchase a new water pump and replace the old pump.
Oct 22, 2009 | GE 24 in. Profile PDW7800 Built-in...
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Glass stove top has a piece that has peeled back
once they are broken they are broken you have to replace he whole top
Feb 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Cooktop glass broken - need a replacement - where can I find it?
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
Dec 23, 2008 | GE Profile JP930 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Replacing glass top on stove
I also have a ge spectra with a broken glass.
Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
GE JSP47 Electric Kitchen Range Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
