Question about HP LaserJet 1020 Printer
Ghost images of the same printing repeated down the page
    Genius:
  • 1,089 Answers
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Posted on Sep 12, 2010
jaylex
  • 417 Answers
SOURCE: Shadows on prints
The comment from Kasmodan2 is true it can the toner cartridge, but is most cases it is the fuser. I repair HP laserjet machines day in and day out to replace the fuser is easy.
  1. Turn power off
  2. Open cover at right hand side rear
  3. Remove data cable
  4. Open top cover remove toner cartridge and press button on right hand side and slide the right hand cover off
  5. Open the back cover and lower the door all the way down
  6. Remove the two silver screws
  7. Take out the paper tray as this will be easier to remove the back cover
  8. Pull the back cover from the bottom and should unclip be careful not to break this cover.
  9. Once open then you will see the fuser unit unplug the connections and remove the screws then slide out the fuser unit
  10. Refit the new fuser unit plug in all the connections and reverse the above process
  11. Turn machine on and test if all good the machine will work fantastic if there is a constant red light repeat above and check connections if still red light then the new fuser faulty and not heating up.
Hope this helps all of you
Thanks J
Posted on Jan 12, 2008
Soulvisitor
  • 1113 Answers
SOURCE: ghost images of the same printed page
Probally your print cartridge, Replace it.
It has a rubber blade that whipes off old image that gets worn, sometimes not near as often it from fuser section..
To find out more see
http://www.fixya.com/support/t243749-words_copied_multiple_times
Posted on Nov 11, 2007
Inky
  • 691 Answers
SOURCE: Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Posted on Jul 23, 2008
  • 141 Answers
SOURCE: Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Posted on Aug 04, 2009
Adi_Taticu
  • 71 Answers
SOURCE: I get ghost images every 2-3 inches down both
run the "cleaning" cycle is the first thing that you should trying.
The Fixing Film Assembly is worn-out. it is a frequent problem.
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v
Posted on Oct 06, 2009
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
My HP 1022 is double printing the text down the page. The repeated printing is very light and fades as you go down the page. there are also some broad light gray horizontal marks down the page. I cleaned...
Observed ghost image:Primary level: Replace with another cartridge & check the qualitySecondary level:Teflon sleeve faulty, replace it if available or replace fuser assm.( Technical skill required for attempt secondary level)
Oct 03, 2011 | HP LaserJet 1022 Printer
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
I am getting a ghost image of what I am printing repeating down the center of the page.
i would say ghost image is more likelly your imaging drum.
some printers have the imaging drum built into the cartridge some have it separate.
i would say try another cartridge
also don't trust remanufactured cartridges if you are concerned with print quality.
Apr 24, 2009 | Samsung ML 1430 Laser Printer
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Print smudges and ghosts down the page
Usually ghosting is caused by the fusing unit, which usually means that it needs replaced to be honest. You could try getting into the fuser and giving the rollers a wipe, they may have dry toner on them which could also cause the fault. but i'd say the fuser could need changed!!!
Hope that helps  (",)
Dec 11, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
Ghost images
Is it from the most recently printed page, or is it the same image avery time regardless of what you print? It sounds like your drum or roller (I'm not sure about the exqact term in english) might be the issue. Have you somehow managed to "force" a printing without paper in the printer?
May 18, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 1020 Printer Logo
2,030 people viewed this question
Seeker5211
Seeker5211
