Question about Intel Motherboard
If i connect 12Vdc connector(4-pin connector near processor) board restarts automatically.
We tryed your recommandation. The problem is not resolved.
Posted on Sep 12, 2014
    Master:
  • 497 Answers
Is there a MAIN POWER CONNECTOR as well? Sometime it is not necessary to plug the small power connector in. Try just the Main one only.
Posted on Sep 11, 2010
Power supply was removed and don't no where to put wires/acer aspire
cable has 20 or 24 pin group it will only go in one way
Apr 16, 2014 | Intel Motherboard
Installation
There are two. One is a 20 pin wide connector. the other one is a 4 pin connector that goes somewhere near the processor. The rest of them are case specific so you'll need to get that information from the instruction sheet of both the mother board and case manufacturers
Jan 25, 2014 | MSI Computers & Internet
Where is the diagnostic port located on a 2000 fiat marea
on a 99 2.0 model you will have 2 diagnostic ports. both of them will be the fiat 3 pin type.
to connect the 3 pin fiat connector to a 16 pin obd2 connector you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to the obd connector.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
Apr 08, 2013 | Cars & Trucks
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
My computer gives continuous long beep on boot. No display on monitor.
Sometimes this means that some connection hasn't been made between the motherboard and the power supply. Often, after connecting the power supply's 24 or 26 pin connector to the motherboard, people forget to plug in the little 4 pin connector. That's usually located near the processor. I hope this helps!
Apr 10, 2011 | ASUS M2N68-AM SE2 Motherboard
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
How do I replace a power supply on a Compaq Presario SR5110NX Desktop PC
you can purchase a power supply from any computer store *********** board supports both standard IDE and Serial ATA connections, so you want a power supply that does SATA power as well. Unplug the power cord from the back of the computer. remove the cover from the case and verify that there is no green LED on the board that is lit up (if there is, there is still power on the board). unplug all connections from the current power supply, including all drive power and the large 24pin plug (actually a 4 pin plug that is combined with a 20 pin plug) on the board, then unplug the 4 pin plug near the processor. careful that the 24 pin plug and the additional 4 pin plug near the processor have latches on the side. Remove the 4 screws that hold the power supply in and remove the power supply, install new supply and reinstall the 4 screws. first plug in the 4 pin plug that connects with the 20 pin, the 4 pin plug has no latch, it is held in place by the 20 pin plug. then plug in the 20 pin plug and the 4 pin next to the processor. then plug in the drive power to all of the drives. Install the power plug at the back of the system and you should see a green LED on the board when you insert the power. replace the cover and power the system up.
Apr 03, 2010 | Compaq Hewlett Packard Presario SR5110NX ...
Pc will not start , power is good - checked ok - replaced processor, fans now turn slightly when power is connected? but nothing else. replace motherboard? philips hepc 7501/05 g33m ms-7357 ver 1 - no...
Make sure the processor is seated firmly. Also make sure that the MB connectors are securely plugged in. Looks like there is a main connector AND a 4 pin connector on this board with the 4 pin being just to the right of the ports that are on the back edge of the board.
Oct 05, 2009 | MSI G33M-FI Core 2 Quad/ Intel G33/...
ASUS P5GD1-VM Motherboard Problems-ok i just got a new borad because my other ASUS P5GD1-VM Motherboard did not work. i put every thing back but it is not working, the green light come on the motherborad...
did you make sure that all the Correct power connectors were in the correct position Different processors and mother boards use different means to get power to the board. On this particular board there are only Two that i can see. there is one in the corner near the CPU that can easily be over looked it is 4 pin and only fits one way(keyed). only having the 20 pin ATX will show power to the board but may not have the juice to power it.
So double check the four pin axillary connector in the corner near the cpu ( upper left) let me know if you already have done this.
Jan 30, 2009 | ASUS P5GD1-VM Motherboard
How to connect the led wires in motherboard
hi use the motherboard manual for this and find front panal connector on motherboard
pin no. 1,3 is for hdd dark color wire is 1 anothee is 3 (hd)
pin no. 2,4 is for power led dark color wire is 2 another is 4 (p_led)
pin no. 5,7 is reset you can connect both side (rst)
pin no. 6,8 is for power on power sw (psw)
most of motherboard folow this diagram
Aug 15, 2008 | Intel Motherboard
Intel Motherboard Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
