Question about Kenmore 98702 Stacked Washer/Dryer
I cant get the washer door open on my 417 kenmore
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!))
Posted on Oct 01, 2010
Kenmore washer front load 417 wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
Front door would'nt open on my kenmore tumble action washer model #417
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 21, 2010 | Kenmore Elite 45986 Front Load Washer
Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Jan 24, 2009 | Kenmore 44072 Front Load Washer
My kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Nov 16, 2008 | Kenmore 44102 Front Load Washer
HOW DO YOU TAKE THE DRYER OFF?
If it is stack from the factory (ie..came as one peice) you cant
Jul 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
37 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
