Question about Century Welding Tools
My century 130 amp , 230 volt wire feed welder, modle # 117-067. it feeds but it does'nt arc. Can some one tell why, and how to fix it?
  • 7 Answers
SOURCE: trying to find a manual for a Pro Arc 1150B 115
Go to proarcwelding.com . I didn't see a manual available,but they have a contact page. If anyone can get you one ,they should.
Posted on Oct 13, 2009
  • 3600 Answers
SOURCE: free manuals
you can order it from Sears but you have to pay shipping.
Posted on Nov 25, 2009
  • 156 Answers
SOURCE: was welding and welder quit acking wire feed and
Check earth wire has not become dislodged,
Pop the cover and check for burnt terminals, often overheating of the transformer can cook a terminal, easily cleaned up and replaced.
Posted on Mar 31, 2010
SOURCE: lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Posted on Sep 06, 2010
eugbug
  • 479 Answers
SOURCE: We need to know how to get an owners manual for
This manual is available for download for $8 at:
http://www.centurytool.net/Century_82021_25_Amp_Plasma_Cutter_Owners_Guide_p/811-656-000.htm
Posted on Feb 15, 2011
I have a Lincoln power mig 216 and as soon as you strike an arc on metal my feed wire either kinks or breaks at the feed rollers and starts rolling out the side I have replaced the tip, liner and diffuser
Are there any kinks in the feed line from the spool to the tip that is causing the wire to not feed? Cut a length of wire and pull it though the feed line to see if there is a lot of friction in it, that would prevent wire feed. Finally, check the wire size - I know, but it is worth checking just in case.
Mar 04, 2015 | Lincoln Electric Lincoln Power MIG 216...
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
Everything comes on and the wire feeds. However it
Check that your ground clamp is connected to the work piece securely.
Mar 14, 2010 | Clarke Power Products Clarke 130EN...
Ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Feb 24, 2010 | Welding Tools
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
I have access to a century mig model 117-3-, 90 amp, 120 volt. the wire feed works and it welds, but it isn't getting 12 volt power to the feed. it might be the circuit board. i know the feed works...
yes its fixable,check the main contactor for proper voltage first,power boards are high dollar,so check the price of new one then decide if you want to put that type of money in the unit.
Feb 01, 2009 | Lincoln Electric LE 83180 Century...
Welding Tools Logo
186 people viewed this question
Top Century Welding Tools Experts
John Trevino
Ted Maxwell
Tom Chichester
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
