Question about Computer Associates CA Internet Security Suite Plus 2008 (ISSP08STDW03)
Once i downloaded and installed CA 2010 Security Suite my internet will not work. the diagnostic tool in IE says internet connection is fine but can't connect to any site. unistalled program and IE is fine. Reinstalled it and IE does not work again.
    Guru:
  • 377 Answers
You can fix this problem through this way
1. Edit the Host File (all the steps explained below) (check if you are able to connect to internet in safe mode with networking ...if not proceed to 2nd step)
2. Change Proxy Settings (if you're still unable to connect to net)
Reimage works by comparing each and every OS system files with the correct files from a web repository of 25 million Windows components. (since Reimage works by comparing with correct file, it can easily find the hiding rootkit, infact this is what a rootkit remover do......dumps a list of files from your hard disk drive and compares it with the list from the recovery console in order to find a hiding virus) This is the sole reason you can get a PC as good as new once you run Reimage, all other antivirus and antimalware programs just delete the virus....but they don't correct the damage...which results in re-infection and slow performing PC.
Reimage first scans your computer thoroughly; all the files, folders, registry keys and values, drivers, softwares, stacks and then either repair or remove those stuffs that should be there. But it's not just that it does. They have an enormous web repository of application, drivers, system objects, etc. from where they compare your PC's files and if corrupted replace it with the healthy ones.
The problem here is Security Suite virus changed the HOSTS File, or changed Proxy Settings.
1. Mend Hosts file: The HOSTS file is used to translate a host name to an IP (Internet Protocol) address without querying the DNS (Domain Name System) server. In general if you know the host name of the machine that serves the unwanted content, you can redirect it to 127.0.0.1, which is the local IP address of your machine.
For example, assume you have redirected the ad.doubleclick.net ad server to 127.0.0.1. Every time your browser tries to load an image or a flash animation from the ad.doubleclick.net ad server, it will be redirected to your machine instead.
As a result, the browser will not be able to show any content from this ad server. The same message appears when a web site is unavailable for other reasons that HOSTS file blocking. The HOSTS file is named 'hosts' and editable with any text editor, such as Notepad or Wordpad.
The file generally appears at: •'C:\Windows\System32\Drivers\Etc\hosts' on Windows XP
Before editing, backup the current HOSTS file. You need to delete all the lines from this hosts file except "127.0.0.1 localhost".
The other entires you saw there need to be removed as they are malicious. (This is why IE unable to connect, because the HOSTS file block the huge list of websites...and you get a warning that "The Page cannot be displayed") After removing the entries from hosts file, please save this file and close it. Now you should be able to search on Google. If not,
2. Change Proxy Settings: Start your PC in safe mode with networking, If you can`t run the IE, then you should repair the proxy settings of Internet Explorer. Run Internet Explorer, Click Tools -> Internet Options. Select Connections Tab and click to Lan Settings button. Uncheck "Use a proxy server" box. Click OK. Click Apply. Click OK. And go to http://reimagepcrepair.com/ to run a Scan.
But one of my subscriber mailed this " But after I unchecked use a proxy server, and then ok, Apply was not an option to click. Another idea?"
So am giving you more options...
1. Run Internet Explorer, Click Tools -> Internet Options
2. Select Connections Tab and click to Lan Settings button
3. Click Advanced button to open Proxy settings. Copy and paste the following text into "Do not use proxy server for addresses beginning with:" go.trendmicro.com;pcfixeasy.blogspot.com;reimagepcrepair.com; (whatever list of web address you would like to use)
4. Click OK to save Proxy settings, then Click OK to close Lan Settings and Click OK to close Internet Explorer settings. (Now you should be able to click 'ok')
5. Download HijackThis. NOTE: before saving it onto your computer rename HijackThis.exe to iexplore.exe
6. Double click renamed iexplore.exe. Then click "Do a system scan only" button and look for similar entries in the scan results as shown below:
R1 – HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=127.0.0.1
O4 – HKLM\..\Run: [{RANDOM}] C:\Documents and Settings\Username\Local Settings\Application Data\{RANDOM}\{RANDOM}shdw.exe
O4 – HKCU\..\Run: [{RANDOM}] C:\Documents and Settings\Username\Local Settings\Application Data\{RANDOM}\{RANDOM}shdw.exe
7. Once you have selected all entries, close all running programs then click once on the "Fix checked" button. Close HijackThis.
8. Go to http://reimagepcrepair.com/ and run a scan
Posted on Sep 11, 2010
I just cant connect to facebook every other site is fine but from my computer it will not let me, i can acces everything else online bar facebook, i went to the internet cafe and it was ok i could get on...
Try adding these to your trusted sites in IE - Tools - Internet Options - Security - Trusted Sites.
https://www.facebook.com/
http://www.facebook.com/
What antivirus/antispyware/security product do you have on machine? Include any you have EVER has on this
machines including those you uninstalled (they leave remnants behind which can cause strange issues).
If no joy something maybe blocking it.
Start - All Programs - Accessores - System Tools - IE with no Addons - does this work better?
IE - Tools - Internet Options - Advanced Tab - click Restore then click Reset - Apply / OK
IE - Tools - Internet Options - Security Tab - click reset all zones to default - Apply / OK
Close and restart IE and/or IE with no addons
any better?
IE - Tools - Manage Addons (for sure disable SSV2 if it is there, this is no longer needed but Java still installs it
and it causes issues - you ever update Java go back in and disable it again.) Look for other possible problems.
Windows Defender - Tools - Software Explorer - look for issues with programs that do not look right. Permitted
are usually OK and "not permitted" are not always bad. If in doubt about a program ask about it here.
Could be a BHO - BHOremover - Free - standalone program, needs no install, download and run - not all
are bad however some can cause your issue (Toolbars are BHO's)
Jan 14, 2011 | Facebook Social Network
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
After I download Norton 2010 (from CD) my comuter
Firstly downland and Norton removal tool to safely remove installed Norton program
To download Norton removal tool
1. www.norton.com/nrt
or
2. www.symantec.com/autotools download and run first tool
Once we finished the un installation we can
To download Norton 360 version 4.0
1. www.norton.com/n360s_4
If are having Norton 36 premier version
go to www.norton.com/n360p_4 to download Norton 360 premier version 4.0
once we finished the installation we can activate with the existing product key If you will get error message like "you exceed number of installation" while trying to activate you need to contact the Norton support to reset the installation count.
Jul 19, 2010 | Norton Internet Security 2005...
Trying to put norton on another pc keeps coming invalid key
I think may be its due to the you are trying to active Norton 360 or Nav with the product key of nis or trying to activate with expierd product key
1.you need to remove existing Norton program with Norton removal tool
2. Download and run Nis2010
to download Norton removal tool go to www.norton.com/nrt or www.syamantec.com/auotools
Download and run the first tool
Once we finished the un installation we need to download and run Norton Internet Security 2010
to download Norton Internet Security 2010 go to this link www.norton.com/nis10
May 12, 2010 | Symantec Norton Internet Security 2010...
How do I cancel a CA Internet Security subscription when I need an activation code for that. CA refuses to provide my activation code.
SPEAKING WITH MY EXPERIENCE: Either try Security Essentials from Microsoft OR Avast. There’s free software out there to try.
Helpful Free Software below Read On.
FREE SPYWARE
Download Spybot Search & Destroy. Restart computer, then run Spybot to see what spyware comes up, AND DELET IT.
FYI---Virus Protection-- 2 programs of virus protection will conflict with each other and will actually cancel out the protection. SO just download one.
Running Spybot Search & Destroy with EITHER Avast or Avg (great Free virus protection programs ) will keep a computer in good working condition. FREE
HERE ARE SOME LINKS, THAT WOULD BE BETTER:
Avira AntiVir
http://www.free-av.com/
NEW *****Somthing new FROM MICROSOFT.*** 2009 ---Security Essentials
http://www.microsoft.com
Pop up Blocker ** free******
www.panicware.com
*****Spybot - Search & Destroy 1.5.2 ****
FREE SPYWARE
http://www.download.com/Spybot-Search-De…
****Avast ***FREE ANTI VIRUS PROGRAM
http://www.avast.com/eng/home-registrati…
****AVG ****FREE SPYWARE PROGRAM
http://www.free.avg.com
**Ccleaner*** FREE
http://www.download.com/3120-20_4.html?q…
***Malware**** FREE
http://www.malwarebytes.org/.
$ *** KASPERSKY ***
http://www.kaspersky.com
There are alot of $ anti-virus and Internet security programs out there,
ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 ,
I feel that is the best for your money.
REMEMBER TO KEEP UP THE DAILY MAINTENANCE ON ALL OF YOUR COMPUTERS.!
Good Luck. If you think this is good information, , please rate me.
Apr 05, 2010 | Computer Associates CA Internet Security...
A popup blocker is preventing me from downloading the link for the CA security suite
Open your internet explorer ,Click tools and turn off the pop up blocker until you finished with the link,then just re enable
Oct 01, 2009 | Computer Associates CA Internet Security...
Need to uninstall Firewall
Assuming you have MS Vista, go to the start menu, control panel, then uninstall software. Scroll down the list until you see CA security suite and high light it, uninstall it.
May 02, 2009 | Computer Associates CA Internet Security...
CA suite downloaded & crashed my computer
Get rid of CA Internet Security. It is normally for 1 year anyway. This CA should have expired already, if you did not purchase the 2 yrs.
There are alot Free Programs out there Better.
Read below.
Go to www.trendmicro.com, and do the free scan Trend Micro's House Call virus, spyware and malware scanner and cleaner. http://housecall.trendmicro.com
If you have anything, remove them. Helpful Free Software below Read On.
FREE SPYWARE
Avira AntiVir – Free Anti-Virus Protection
FROM MICROSOFT 2009 -Free --Security Essentials
Pop up Blocker- free
www.panicware.com
Spybot - Search & Destroy 1.5.2 -FREE SPYWARE
Avast- FREE ANTI VIRUS PROGRAM
AVG- FREE SPYWARE PROGRAM
Ccleaner- FREE
Malware- FREE
$ *** KASPERSKY ***
There are alot of $ anti-virus and Internet security programs out there-ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 , I feel that is the best for your money.
If all else fails, then do a Reformat. You will loose everything, so do a Back-up.
Good Luck.
Feb 15, 2009 | Computer Associates CA Internet Security...
JS.Blackmal.F "Removal
try running ComboFix, it is freely available for download
Jan 31, 2008 | Computers & Internet
Computer Associates CA Internet Security Suite Plus 2008 (ISSP08STDW03) Logo
733 people viewed this question
Top Computer Associates Computers & Internet Experts
k24674
Jay Plesset
Are you a Computer Associates Computer and Internet Expert? Answer questions, earn points and help others
