Question about Samsung NC10-14GW Notebook
My netbook,model nc10 ,the display becomes white suddenly and tilting the screen up and down it may ir maynot return to it's normal one.
    Guru:
  • 689 Answers
Sounds like you have a problem with your screen/pc connection at the base of the hinge/keyboard. only dismantling and repairing this type of connector would repair you pc--tricky i admit.
Posted on Sep 11, 2010
Brighten display screen
Normally, on the keyboard of your netbook, there is a "Fn" key next to the bottom left "Ctrl" key.
after you finish booting up and have the screen veiw, press and hold the "Fn" key, then at the top there are a row of "F' keys, usually the F6 key is the key you would press to increase the brightness of your display. Each time you press the key the brightness should increase, if you press it pass the maximum brightness it will go back to a low brightness and then increase in brightness each time you press the "F6" key.
Remember, you have to hold down the "Fn" key as you press and release the "F6" key.
**** Luck
Aug 27, 2011 | Samsung NC10-14GW Notebook
I have a Netbook NC10 and my screen wavers all the time it has become almost unusable. I live in the Durban area of Kwa Zulu Natal South Africa
http://www.notebook-driver.com/samsung/sumsang-nc10-netbook-pc-windows-xp-drivers/
Visit the address above for your original drivers.
May 23, 2011 | Samsung NC10-14GW Notebook
My samsung netbook NC10 has the following problems, i would like to know how i can resolve it: 1. When i put it on charge, i cannot use it, the screen goes white 2. When i take out the charger, the...
Its mainly occur in hardware problem only.. In Western Cape South Africa also samsung service centres is available....I attached the address below go and check it there...your problem will be solved...
CG Appliances centre
no:66 st john street oudtshoorn oudtshoorn,western cape
mail address:cgappliance.centre@odn.co.za
Jan 01, 2011 | Samsung NC10-14GW Notebook
My Samsung NC10 netbook has died suddenly today, it had been working fine but hd gone to sleep autmatically on powersaving mode. On trying to reactivate, a white screen appeared and there was a constant...
The fault is in the motherboard - it can't be fixed, you will have to replace it. Take the netbook to a repair shop , this is a very complicated job.
Oct 17, 2010 | Samsung NC10-14GW Notebook
My NC10 netbook works normaly until i try to run it with the power cable plugged in ...the screen goes blank (white)...unplug the power and it runs OK. roger.
first thing i to check psu model specs,(should be on sticker on psu) is as supplied with your model(manufacturers site)
Sep 11, 2010 | Samsung V20 XTC 1800 Notebook
I replaced a cracked lcd screen on my wife's toshiba netbook NB205-N313/P. First let me describe what happened. The netbook fell and the screen cracked and I connected to an external monitor and had to...
Check the ribbon-cable between the motherboard and the LCD screen. It is not transmitting 100% of the video-information.
Be sure that it is not "crinkled", and that it is tightly connected at each end.
Sep 10, 2010 | Toshiba Mini NB205-N313/P Netbook
NC10 netbook screen keeps "whiting out"
If you have to wiggle it on the hinges then it sound like it is a bad ribbon cable connection, it it has somehow broken. There is a thin flat ribbon that runs from the pc to the display. Some patience and care will required. If at a ll possible, take it to an authorized service center, should still be under warranty. Best way to test if from one end to other (pin to pin) for continuity with a volt meter.
Jul 18, 2010 | Samsung NC10-14GW Notebook
My NC10 netbook screen is blank (dead) when powered on
try looking for an FN button and an icon on your keyboard that has 2 screens on it one is blank and one has an outline in it Hold the FN button down and press that key with the icon usually the icon is blue on a keyboard and is on the F1-12 buttons or on the numberpad
Apr 09, 2010 | Samsung NC10-14ROBL Notebook
If i put the charger in the screen goes completely white, but when i take the charge out its fine. What is causing this to happen.
I have an NC10 and it is doing the same. if you press fn+down keys together 2 or three times, it will darken the screen and no longer be white, I know it sounds weird but it is just a workaround that works.
Another one to try is to tilt the screen backwards.
I think there is an inherent problem with the screen that has to do with the voltage. Hope it helps.
cheers,
Ron Gange
Feb 15, 2010 | Samsung NC10-14GW Notebook
Samsung NC10-14GW Notebook Logo
89 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
