Question about Danby DWC283BLS Wine Cooler
My Danby DWC283BLS makes a groaning sound which goes on and off every few seconds. It is loud and annoying. Too loud to ignor.
  • 10,515 Answers
This means one of two things the overload relay is bad or the compressor. Pull the unit out remove the back panel there is a box on the left side of the compressor take it off and shake it if it sounds like glass is inside the relay is bad if it does not the compressor is locked up and kicking off on the overload making that noise.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
Recently, the wine fridge has started to make a whirrring sound that lasts around 4 or 5 seconds, then stops for around 20 or 30 seconds, then starts whirrrring again. Sounds a bit like a man moaning....
it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Canby may be reached at the following link:
http://danby.com/customer_service
May 21, 2011 | Danby DWC283BLS Wine Cooler
My Danby has become loud and it sounds like maybe an issue with the fan. What should I do?
might be that the fan blades strike the casing. switch of your cooler. pull the plug out to prevent el-schock. turn fan blades manually and observe....
Mar 03, 2011 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
Compressor makes noise and goes on and off constantly
That foam block is an anti vibration dampening device. My guess is is goes up against the underneith od that compressor. The real problem is with the short cycling compressor. I would return that piece of junk.
Jun 30, 2009 | Heating & Cooling
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
Danby Wine Cooler Chatter
The compressor has rubber grommets that isolate/insolate it from metal on metal. What is happening is that one of these has worn through and now when the compressor kick in or out it shake which is normal but gives you that metal on metal clanking which is not normal. Look at the back and see where the compressor is held inplace by pins you will see rubber donuts/grommets. One or more are wore out. You can probably find some on a unit at a salvage yard on a small fridge and you may be able to buy some an appliance supply warehouse....
Nov 02, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
253 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
