Question about Electrolux Featherlight Gas Blower, 150 Mph, 300 Cfm, Weighs Only
Blower wont stay running. - Electrolux Featherlight Gas Blower, 150 Mph, 300 Cfm, Weighs Only
    President:
  • Electrolux Master
  • 1,545 Answers
Unfortunately, there could be a number of things causing this problem,however...most of the time it is a fue delivery problem (carburetor) and usually requires upgrading the entire fuel system..that it ...fuel filter in the fuel tank..fuel lines...carb rebuilt with a diaghram kit or a full rebuild kit...but that is most likely the problem...the small and delicate parts inside the carb are shot and need to be replaced. Make sure your spark plug and air cleaner are both clean too. Carbon build-up is a problem also and occurs at the outside of the engine and inside the muffler (esp. on older machines).
Please vote on this solution
Posted on Sep 11, 2010
Why won't blower shut off?
03 - 06 Silverado/Sierra blower stays on with key off (how to ...
? 1:32
https://www.youtube.com/watch?v=PkltkvLDhIg
Apr 7, 2014 - Uploaded by MAY03LT
The HVAC blower in this 2003 Silverado stays on speed 5 even with the key off. Here's how to turn speed 5 of the blower off(while keeping speeds 1-4) and ho. ... How to replace blowermotor resistor in Chevrolet Silverado - Duration: 5:06. ... 2004Tahoe rear brake service (replace pads, clean/lube slides, ...
Blower motor won't shut off. - Diesel Place : Chevrolet and GMC ...
www.dieselplace.com/.../76.../208669-blower-motor-wont-shut-off.html
Jan 10, 2008 - 11 posts - ‎7 authors
I have read through many posts on blower motor issues but no one had the same issue I have. ... If I shut the truck off, it still won't shut off and runs until the battery is dead.... 2002 GMC Sierra RCLB 1500 4X4 SLE, 7 1/2' Fisher plow.
Question - Blower Motor Won't shut off ' Chevy Truck Forum ' GMC ...
www.gmfullsize.com > General > Maintenance
Dec 11, 2015 | 2004 Chevrolet Silverado 3500
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
2010 jeep blower stays running after button off
changing the blower motor was a waste of time and money, you have power going to the blower after the switch (button) is turned off, could be a bad switch
Jul 14, 2014 | 2010 Jeep Liberty
Will start with chock on but wont stay running with it off
the idle jet or the float valve is blocked
you need to strip the carb and unscrew the jets and clean them
i use small interdental brushes ...
Mar 23, 2014 | Stihl Blower Handle Moulding Bg Sh 45 55...
Weedeater 25cc Blower
Its obviously fuel starvation, start withe the easy stuff first, use a peice of bent wire to hook the fuel line out through the open filler hole, the filter on the end then needs to be pulled off and replaced, try this first before we get into the carb.
Jun 25, 2013 | Garden
My Echo lea blower wont stay running after two minutes or so
try and run it without the muffler if ok without it pry it open and clean it
Apr 18, 2012 | Garden
1995 jeep grand cherokee blower wont shut off EVER.
YOU HAVE A FAULTY BLOWER MOTOR RELAY.IT STAYING CLOSED.CAUSING BLOWER MOTOR TO KEEP RUNNING.
Oct 03, 2009 | 2000 Jeep Grand Cherokee
32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Jun 29, 2009 | Craftsman 4 Cycle Blower/Vac
Electrolux Featherlight Gas Blower, 150 Mph, 300 Cfm, Weighs Only Logo
173 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
